Question about Packard Bell Computers & Internet
Change hard drive
Need to remove the old hard drive
    Master:
  • 409 Answers
And how may we help you?
Posted on Nov 20, 2013
I need to know how to retrieve my files from an old hard drive on a new laptop or desktop, how & where do i install it, the prongs don't seem to match.
You will need a few items to get data off of your old Hard-Drive.
If you have already removed the old hard-drive you'll need something like this:
http://www.amazon.com/Cables-Go-30504-Serial-Adapter/dp/B000UO6C5S/ref=sr_1_2?s=electronics&ie=UTF8&qid=1352401035&sr=1-2&keywords=sata+usb+adapter
to attach to another machine to extract the data.
Your old HDD will act like a external hard-drive and you can retrieve your data that way.
Hope that helps
Nov 08, 2012 | Seagate Momentus 40 GB Hard Drive
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
Changing hard drive / do i have to reinstall os?
If the old hard drive is still working, then you could make an image of it and restore that image on the new hard drive removing the need to reinstall the Operating System.
There are several free programs available that can make the image:
Easeus Todo Backup
Paragon Backup & Recovery 2012 Free Edition
If the old drive has failed and you do not have a full backup, then you will need to reinstall the operating system and all your programs and data that was on the old drive.
Jan 16, 2012 | Compaq Presario 7594 PC Desktop
Have replaced computer. Motherboard dead on old one. Is there any practical way I can get pictures and such from old computer. It will not power up. Thanks
You should be able to tak the hard drive out of the old one and put it in the new one as a secondary drive. There is a good chance, though, that the drive won't fit. If it doesn't, you'll need something like this.
Mar 02, 2011 | HP Pavilion a450n PC Desktop
I want to change hard disc, need instruction how to replace the old disc and install new one
There should be a removeable panel on the bottom side of the laptop that covers the hard drive. there might be several, so you may have to remove several panels before you find the hard drive.
To remove the hard drive, slide it away from the connector side to unhook it, then lift it up and out of the compartment. Examine the connector side of the hard drive, because there is probably an adapter affixed to the connector/contact. remove the adapter (if applicable) and put it on the new hard drive, then drop it down into the compartent and slide the new hard drive in towards the connection to connect it.
Now, you will need the windows disk that came with the computer to reinstall windows. if you do not have a disk, you can order one from sony.
if, instead of starting with a fresh windows install, you wish to copy windows with all of your data to the new hard drive, you will have to hook up both the old and new hard drive up inside a desktop and use cloning software such as Archaos makes to copy the old disk's data onto the new one, windows and all. These hard drives may be smaller than standared hard drives, but once the adapter is removed, they have the exact same SATA connectiuons as do standard desktop[ hard drives and will hook up to a SATA capable desktop (any made within the last 5 years) just fine.
Nov 30, 2010 | Sony VAIO VGN-SZ220/B Notebook
My Iomega 1 TB desktop usb 2.0 hard drive stopped working. it makes a ticking sound and turns off on it's own.
This means that your hard drive has died so will need to be replaced. This is what you need to do:
1. Buy a new hard drive
2. Open up the casing of your old device
3. Remove the old hard drive
4. Place the new hard drive in the bay
5. Re-assemble the casing and plug in
Feb 22, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Very low on hard disk space!
YOU NEED TO BUY A LARGER HARD DRIVE.YOU CAN GET A 250GB.DRIVE FOR AROUND $100USD OR LESS.ONCE INSTALLED MOVE/TRANSFER FILES TO NEW DRIVE.
Nov 30, 2008 | Computers & Internet
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
How do i fix a hard drive on a lap-top
You need to remove the old hard drive first. Depending on your model, there should be a screw or two on the bottom of the computer that gives you access to the hard drive. You remove the old drive, take it out of it's caddy, take the special connector off of it and install it on the new drive, put the new drive in its caddy, and replace the hard drive.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | Gateway Computers & Internet
Computers & Internet Logo
14 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
