Do i need a new battery as it no longer charges
I have just purchased a phone plugged it all in have you to wait till batterys have charged for it to work
Usually you need to wait about 15 hours for the new phone batteries to charge up.
Oct 02, 2016 | Lands Phones
When battery has been fully charged, the charge only lasts 1/2 hour before it needs to be re-charged.
I would assume that the battery is old. With time batteries looses a bit of charge, and their life get worse. You should just buy a new battery and the device will work longer for sure.
Oct 19, 2015 | Shark SV1106 Navigator Cordless Upright...
J.d. Pa540a not charging?
how often do you charge it ?
If you are charging it every night the battery may have lost it's zero point. In simple terms this means the battery can no longer hold anymore charge and you need to buy a new battery.
Sep 19, 2013 | Cell Phones
Battery keep goin dead after 2days
need a new battery... your battery can no longer hold a charge. mine did the same thing. they only last so long... eventually they can no longer hold there charge then theyre useless
Sep 17, 2013 | 2001 Dodge Durango
Ma fone's bettery runs down every five minutes i charge it
this is happening because your phone battery is defective or has gone bad.
The cell in the battery is weak such that it cannot hold charge any longer.
All you need now is a new battery.
Once you install a new battery, your phone will last longer again.
I hope the above is clear.
Good luck.
Jun 29, 2011 | Samsung SGH-D600 Cellular Phone
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
LG VU,battery indicator shows fully charged but I can only talk a couple of minutes before phone shuts off and shows dead battery? Just a dead battery or something else going on here?
I believe the cells of your battery is very weak that is why it can no longer hold charges for long.
All you need to do is to get a new battery on your phone and makesure you charge the new battery to its maximum capacity before you start making use of it.
This will help preserve the life span of the battery and make it last longer.
Take care.
May 02, 2010 | LG Vu CU920 Cellular Phone
Why does my ds lite not power up
Does the battery light flash? If red: CHARGE! If doesn't charge, a new battery is needed If green: New battery is needed
Batteries lose their charge holding capabilities after being used for a long period of time. DS lite batteries have a price range from around 4-20 dollars depending on the web site/store and the quality, some can go longer without charging, others can be charged a higher number of times so you won't have to buy them all the time.
If the light doesn't flash: I am not sure. I think a new battery should fix that too
Oct 25, 2009 | Nintendo DS Lite Console
My son's nintendo ds has been charging for a day now, but it
The battery is probably completely drained. Rechargeable batteries have a certain lifetime in which they can be charged to. The charge limit for a Nintendo DS is approx. 500 charges. When you pass this limit the battery will no longer work. Your best option is to buy a replacement battery at http://www.nintendo.com/consumer/
After a year or more a rechargeable battery won't last as long as it did when it was new.
Apr 07, 2009 | Nintendo DS Console
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
