Question about Hardware & Accessories
Noma 052-8823-0 looking for instructions for setting on and off times
Hi, I have a Noma moonrays 88 watt timer with two buttons on the front and a display from 0 to 9. the top button seems to be a manual/auto switch and the bottom one has a clock symbol, but i can't
1) Copy following link for to identify timer, and possible instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Add comment and say what you discover about setting timer
3) Look on timer, and sometimes the instructions are printed on paper label
Dec 09, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Moonrays noma landscape 9 hour power supply. cannot figure it out
You have the 9 hour 200 watt Moonray.
Copy following link to identify timer and see basic instructions by pushing button and cycling throught choices.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
Sep 23, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hi I sent this enquiry to small appliances in error so am resending here. Thanks and await your reply. Hello, I'm house sitting for a friend and I accidentaly disconnected their Lightning model No...
I'll take a shot at it, although I can't find a manual.
There are 5 buttons that you can push:
Reset, Set, +, -, Enter.
Inserting a pin in the Reset hole will erase everything.
You probably press Enter to cycle through Program 1, 2, 3, 4, 5, 6, Auto, Manual. Then use +, - to set the function, such as On time or Off time.
Then use Set to program.
In other words, to set the lamp to go on at 6pm and shut off at 11pm:
Press Enter until you see Program 1 flashing or highlighted in some fashion.
Use + or - to set the On time, press Set.
Use + or - to set the Off time, press Set.
Try this and get back to us.
Gary
Dec 21, 2010 | Hardware & Accessories
Instructions how to programme noma model N1507 timer
I posted N1507 manual yesterday but have not heard yet if this is correct manual
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment and say if these instructions match your timer.
Dec 06, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I have lost the instructions how to set a noma 7 day timer model N1507
Link show all Woods timers and manuals.
Noma is one name used to market Woods timers
Woods N1507 is also 49565
Woods N1507 manual
Add a comment if this manual does not match your timer.
Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM ET525C Manual
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
Nov 28, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do you set a older outdoor noma light timer only 2 buttons
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour Heavy Duty Outdoor Timer
Regards.
Ginko.
Jul 21, 2010 | Home
Lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Dec 01, 2008 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hardware & Accessories Logo
122 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
