Question about 2012 Cadillac CTS - 3.6L, coupe - Sunbrella Extreme Sun Car Cover
I have a CTS coupe 2012, and i would like to know if i can lock my doors without using the Remote since i can unlock them without using the remote. Thanks
Door locking without usng remote
    Sergeant:
  • 193 Answers
Try locking from inside hold door handle trigger while closing door be sure you have you keys with you before closing the door.
Posted on Dec 11, 2013
How do you program a keyless entry fob for a 2012 monte carlo
Close all the vehicle doors. Insert the ignition key into the ignition lock cylinder. Press and hold the DOOR unlock switch. While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode. Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter. Repeat the previous step to program up to four transmitters. - See more at: http://theandrewhughes.com/2007/05/how-to-program-most-gm-key-fobs/#sthash.6oXk0NFT.dpuf
Jun 07, 2015 | Chevrolet Monte Carlo Cars & Trucks
2008 Cadillac CTS rear passenger door wont unlock with the remote. all other doors and trunk work. must manually lock and unlock door that door. anyone know what the issue is, and is that something I...
see the diagram attached. YOu must test the mechanism for lube, or damage parts, loose wires or connector corroded, switch dirty Lube WITH wd-40, test the motor or solenoid
God bless you
Nov 27, 2013 | 2008 Cadillac Cts
Doors won't lock, thinks key in ignition
Troubleshooting is required to inspect few parts.It can be issue with ignition switch.Its not getting off.Or issue with sensor or wiring.Or its faulty lock itself.Click the link below and follow the troubleshooting:----Driver Door will not lock or unlock with Key or Remote? http://whatisbyme.blogspot.in/2012/05/1998-toyota-landcruiser-driver-door.html
Driver side door will not lock or unlock with Remote? http://technoanswers.blogspot.in/2012/04/2009-toyota-tundra-driver-side-door.html
Central locking not working ? http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
Jul 17, 2012 | 2002 Subaru Outback
How do i remove and replace drivers side door window
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----
drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
This will help.
Thanks.
Feb 23, 2012 | 2003 Oldsmobile Alero
Power door locks won't lock
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
All power door locks not working?
Central locking not working?
This will help.
Thanks.
Feb 07, 2012 | 1993 Pontiac Grand Am
Remote Starter not working
This will help.
Thanks.
Feb 05, 2012 | 2006 Chevrolet HHR
1999 Ford Windstar power door locks only work when key is turned on
This will help.
Thanks.
Feb 03, 2012 | 1999 Ford Windstar
Remote will not lock or unlock doors on 2003 Cadillac CTS
It's time to replace the battery in the remote. They use a regular button cell, available at most battery racks.
Nov 16, 2009 | 2003 Cadillac CTS
I need to program a key fob for a 2004 Cadillac CTS. I just purchased the car used. it came with ONE key and nothing els. I have recently purchased a keyless entree remote suitable for the car and was...
Remote Key FOB Information
Transmitter Programming
 1. Close all the vehicle doors.
   2. Insert the ignition key into the ignition lock cylinder.
   3. Press and hold the door unlock switch.
   4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
   5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
   6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
   7. Repeat the previous step to program up to 4 transmitters.
   8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
   9. Operate the transmitter functions in order to verify correct system operatio
Sep 17, 2009 | 2004 Cadillac CTS
2004 infiniti g35 coupe doors do not lock with button/remote
can you unlock them with remote if not and you have changed the battery in it the remote has probably lost its programming. if you can the circuit for the unlock is probably bad.
Aug 28, 2009 | 2004 Infiniti G35 Sport Coupe
2012 Cadillac CTS - 3.6L, coupe - Sunbrella Extreme Sun Car Cover Logo
108 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
