Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Vac brush not working on carpet - Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
  • Official Brand Answer
  • 2,572 Answers
Hi Dawn, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC17. If the brush bar isn't rotating, it may just need to be reset - for guidance on doing this, please take a look at the video above.
The brush bar is engineered to shut off automatically if something jams it, so it's important to keep it clear of any threads or hair.
I'm confident this will resolve the issue, but if you would some like further assistance after you've given this a try, please give us a call on 1-866-693-9766 (US, or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Posted on Nov 20, 2013
I have a rug doctor carpet pro its red. Brushes will turn, hand tool will work but when on carpet won't spray water
Take it to your local vac shop for diagnosis. Sounds like a bad pump, or possibly a bad pump switch. It could also be a stuck diverter valve
Feb 19, 2015 | Carpet Pro Vacuums
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My Sanitaire vacuum is not picking up well - works ok on floors but not on carpeting
Depending on the model you may have a single or two motor system. If it is not running well in carpet mode but still has suction check to see if the brush for the carpet head is turning. If not look for a red reset switch or spin the brush when the vac is shut off. It it spins freely the belt is either broken or badly stretched and needs replacement.
Sep 05, 2009 | Vacuums
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
Apr 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Carpet height selector doesn't work.
You have a bad belt. It may not be broke but it's so loose that it isn't turning the brush roller when a little resistance is applied to it. That belt is cheap and it's routine maintenance to change it about every 6 months. You will notice a big difference when you put a new one on.
Nov 22, 2008 | Vacuums
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
