Question about Dryers
Casablanca fan with light, when I turn the power on at the wall, fan turns on high, but does not respond to turn on light or change fan speed. Wall remote is wired.
When I turn the power on at the wall, fan turns on high, but does not respond to turn on light or change fan speed. Wall remote is wired.
  • Mike Schmidt
    Mike Schmidt Oct 07, 2014
    If you can take the fan apart, find the power board. Look at the capacitors and see that the tops are flat, if rounded they are bad and need to be replaced.
    Genius:
  • 1,617 Answers
Probably needs a new receiver.
Posted on Nov 20, 2013
  • Dave
    Dave Nov 27, 2013
    Thank you, looked and the reciever is actually melted... can I replace it with a Lutron wall control and reciever? MA-LFQHW-WH? Thanks!
  • Fan Fair Of Boca
    Fan Fair Of Boca Nov 27, 2013
    If it's an add-on remote then you might be able to. Do you know the make/model of fan?
4 Suggested Answers
outdoorsman5
  • 631 Answers
SOURCE: Hunter 93886 fan
You may be drawing to much amperage for the switch to handle both fans. You may be underwired if it is an old house. you can hook wires together without switch in place and see if everything keeps working but don't hook them together with the power on. Also don't run very long as the wires could heat up. Run for about 5 minutes and turn power off and check heating of wires.
Posted on Jul 28, 2009
  • 109 Answers
SOURCE: my casablanca fan/light wall switch only works
No . have this checked by a licensed professional it is more than likely bad switchs in the fixture but you can never be to careful with electricity
Posted on Aug 23, 2009
caroldon
  • 17129 Answers
SOURCE: Hunter remote control fan wired
For a possible solution to your remote please check and see if you can get your remote working with this link for tips;
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Sep 29, 2010
Casablanca Isatope 52 inch fan not working
The combination of wall switch control and remote control tends to throw the unit into a tizzy. Try disconnecting power at the source and starting all over again. You may have to abandon wall switch control and rely solely on the remote.
Apr 02, 2017 | Casablanca Fan Televison & Video
Casablanca intellitouch 3 light flicker
Call Casablanca at 1-888-227-2178
Feb 19, 2013 | Dryers
Casablanca fan has totally stopped working
Probably need to reset receiver in fan. call 1-888-227-2178 and somebody should be able to help you with that.
Dec 29, 2012 | Casablanca Fan Dryers
I have three casablanca fans in three rooms. An electrician installing electrical outlets, in the attic says he only accessed the main power line. However, all three fans suddenly malfuctioned in the
Are the fans all on one main line just for the fans and are they plugged into a GFI receptacle. If so you may have to reset the GFi or maybe your electrical box needs to be reset.
Jun 12, 2017 | Casablanca Fan Panama II 50" Ceiling
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
I have a Casablanca ceiling/fan light with one wall switch. The fan will only work on high speed and makes a shrill type of noise. The light has worked but not consistently. I was wondering if I have a...
is the switch made to turn on and change the speed, the switch is acting up should chang the switch, but if you change the speed with the chains the wiring is loose up in the fan just need to take it down and tighten up the connections,good luck.
Aug 08, 2011 | Casablanca Fan 3245T Ceiling
My casablanca fan/light wall switch only works
Aug 23, 2009 | Dryers
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Dryers Logo
244 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
