Question about Toshiba (MK1059GSM) 1 TB Hard Drive
Mk1059gsm I have connected the toshiba 1tb hard drive to usb drive but window 7 is unable to open the drive.
4 Suggested Answers
rajeshpait
  • 542 Answers
SOURCE: toshiba 1tb external hard drive won't connect
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
7. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
8. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Posted on Dec 16, 2009
  • 608 Answers
SOURCE: I have a dell studio XPS laptop with 64bit version
Somehow you have scheduled a scandisk operation. The instruction for the PC to do this is stored in the registry. If you use a registry cleaner, such as ccleaner, you should be able to remove this request.
Posted on Apr 14, 2010
  • 11800 Answers
SOURCE: i just bought a brand
No, a disk that fails so fast is very rare - clearly a manufacturing defect. Take it back to the dealer and have it fixed under the warranty.
Posted on Jun 17, 2011
The hdd portable fall from me to the floor and now there is abnormal sound and not discovered on the laptop
so sad but hard drives are delicate precision pieces of technology and are not meant to be bounced from the floor
roughly put the laser eye that reads the disk is faulty and the hard drive is failed
any data is lost
Nov 20, 2015 | Toshiba 1TB MK1059GSM HDD2K11, 5400-RPM,...
My Toshiba v63700-c 1TB external hard drive worked great in Window 7. My v63700-c does not like Surface 3 Pro. Do I need a new cable?
Somewhat depends on what "does not like" actually means. So far, I've not found any USB item that works differently on my Surface than on my laptop or desktop, Windows 7 or 8.
Is there an error message? What does it say?
Apr 14, 2015 | Toshiba Computers & Internet
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
Upgraded from windows 7 to windows 8 ,now storage device not showing.
Have you tried to shut down the computer, unplug the usd external drive, reboot the computer, plug in the USB external HDD the should apply the driver. That said, Have you tried a Thumb Drive or any other USB device in the USB ports? It's a common problem when upgrading a OS that Hardware issues popup. Open the Device Manager, Is your USB controller working? Enabled? Any other devices in error? Unknown devices? Use the Win 7 drivers for your computer found on the computer manufacturer's website. Change the compatibility on the driver for Win 8.
Jan 11, 2013 | Western Digital 1TB WD ELEMENTS USB...
I think my hdd is broken, windows does not recognize it.
I have the same problem. It's too late, I know, Diego, but I found this silly solution that I am posting that might work for others. Plug the Toshiba HDD into another USB Port: (Probably Windows OS retains each stream that it has started, and these streams need to be deleted, in the same sense that some apps won't open the file it has open currently.) I read in another forum that the computers USB ports had been fried after a power surge!
Might work for someone.
Jun 11, 2012 | Toshiba HDD2H92) 500 GB SATA Hard Drive
My hard drive is unable to open and format
You will probably need to remove the drive and use another computer to format it. You can buy an adapter to connect it to another pc as a USB drive and format it this way. They are not very expensive. Hope this helps.
Jul 17, 2010 | Toshiba Satellite A215-S4747 Notebook
External hdd not working as should
Hi, click on the "Start Button," open All Programs, select the Icon for the (Name) of your Computer; example "Toshiba," next after opening it, choose "Utilities." Once the window open, click to open the by the name you see: CD / DVD Application, or DVD-RAM Utility; now you can [Format] the DVD-RAM Disc accordingly. "If this was helpful to you? Rating the solution is apprecaited, thanks."
May 20, 2010 | Western Digital My Book Essential 1TB...
I have a dell studio XPS laptop with 64bit version of Windows 7 installed. I connected the Toshiba 3.5 External Hard Drive (1TB) to it and backed up the computer. I disconnected the USB when finished and...
Apr 14, 2010 | Toshiba Computers & Internet
Open Questions:
See all Toshiba (MK1059GSM) 1 TB Hard Drive Questions
Toshiba (MK1059GSM) 1 TB Hard Drive Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
