Question about Nissan 1991 D21 Pickup Engine/Motor g68409329n 4 cyl KA24E, VIN S, 4th digit, 4x2 New Orleans, Louisiana
1991 nissan pickup will not go into overdrive
Wont go into overdrive when on the highway
4 Suggested Answers
  • 10 Answers
SOURCE: Can't get the starter out of a 1991 Nissan pickup.
The second bolt is hidden way up and tucked in near the solenoid. You need to setup a ratchet with extensions/socket (14mm) combination that is just a little longer than the starter motor. If you just can't picture where the bolt is, then go down to the parts store and look at/purchase the replacement starter to see how it mounts up.
There are two bolts for the starter mount and one nut for the main starter power lead. There is one plug for the starter key switch.
Disconnect plug. Loosen lower bolt. Remover upper bolt. Remove lower bolt. Twist starter so you can remove main power cable nut (be sure to have disconnected the battery first!) Pull starter.
Posted on May 10, 2009
kidspeedy
  • 321 Answers
SOURCE: firing order
do not get the firing order mixed up.
if you have it mixed up allready do not try to run it untill your sure about the order.as you will distroy the engine.yes distroy.
firing order should be cast on the engine or intake somewere there.what kind of pickup and what size engine.if i can have this info i will get the firing order to you.
hope this helps
thank you
jm
Posted on Jun 16, 2009
  • 509 Answers
SOURCE: need engine size in Nissan pickup
It is either a Z24i, or a KA24E. You should find the identification number on the left side of the block at the rear. It should say what size it is.
Posted on Jul 07, 2010
I have a nissan 4x4 pickup 1991 and has broken one leaf sprins
Your best bet,is to search the local junk yards.
Nov 25, 2013 | 1991 Nissan Pickup
Repair manual for 1991 4x4 nissan hard body pickup
Yeah Joe,Nissan's are well known for head gaskets to blow.Here's a link to replace head gasket.
Feb 10, 2013 | 1991 Nissan Pickup
Where is nissan 93 pickup overdrive relay
where is the overdrive relay 93 nissan p/u
May 24, 2010 | 1993 Nissan Pickup
Where is the speed sensor located?
PROBLEM COULD BE IN THE DOWN SHIFT SOLENOID.
Apr 18, 2010 | 1991 Nissan 300ZX
Takes a long time to shift into overdrive
sounds like the toque converter is locking and unlocking have the trans serviced and flushed if this does not cure the problem then you could be looking at a trans rebuild or replacement.Check the fluid first could just be low.
Jan 02, 2010 | 1991 Toyota Pickup
1991 toyota p/u auto trans wont shift to overdrive
The trans in your truck had some problems in that era with overdrive. You will need ot check a few things to be sure it is not internal. The overdrive would often fail in those units due to the o rings used instead of lip seals.
Check the temp sensor. If it is bad the trans will not go into od. A defective solenoid in the trans for overdrive could cause it not to go in.
Check the fluid, if it is black, you may have burnt the clutches. I have know people who have driven the toyo's for years with no od. It is the same as the old three speed auto.
Hope this helps
Nov 19, 2009 | 1991 Toyota Pickup
Firing order
hope this helps
thank you
jm
Jun 16, 2009 | 1991 Nissan Pickup
How to use the overdrive on the auto.transmission.
the overdrive button on your automatic transmission is for cruising on the highway basically like having another gear for better economy careful not to use it when your not on the highway because lugging the car in overdrive when its not needed will cause higher fuel consumption other than that you should have no problems just get out on the highway and push and away you go
May 31, 2009 | 1991 Toyota Camry
1991 nissan engine
check the distributer cap same problem with my 91
Feb 23, 2009 | 1991 Nissan Pickup
Nissan 1991 D21 Pickup Engine/Motor g68409329n 4 cyl KA24E, VIN S, 4th digit, 4x2 New Orleans, Louisiana Logo
65 people viewed this question
Top Nissan Car Audio & Video Experts
xxxxxx xxx
Are you a Nissan Car Audio and Video Expert? Answer questions, earn points and help others
