Question about Yard Machines 6.5 Amps-Amp 9" Electric Cultivator Y155
Machine won't start
Despite doing everything I can think of
Whirlpool washer won't start. Not a water problem. Door lock lift on or at times flashing. Think it's something to do with the door or panel.
At the right end of your panel you will find the 'end of cycle' symbol, to unlock keep this depressed for 3 seconds, this is the child lock feature. You do it again, and the machine locks.
Click if helped......
Apr 20, 2013 | Washing Machines
2008 escape hybrid won't start when you turn the
I am not familiar with hybrids, but i think when you start, it's starting with the battery, so I think you have a bad connection, check and clean the battery terminals.
Mar 25, 2013 | Cars & Trucks
My car won't start
If your battery is low it will work everything but will not operate starter motor
May 12, 2012 | Mercedes-Benz SL-Class Cars & Trucks
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
I just purchased the sew pro portable zig zag sewing machine model zz 401 and it won?t work, the pedal makes this funny sound and the machine isn?t working. What do i do? I tried everything and tried...
Maybe the drive wheel is disengaged. Some machines have you pull out the wheel on the right to wind a bobbin and yours might be pulled out. Try pushing the wheel back in to engage the machine.
Nov 09, 2009 | Steam Fast ZZ-401 Mechanical Sewing...
My Indesit Washing machine doesn't seem to start?
Most likely water has short-circuited your controls; you need a specialist here.
Apr 09, 2007 | Indesit W 123 Front Load Washer
Yard Machines 6.5 Amps-Amp 9" Electric Cultivator Y155 Logo
75 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
