Question about Brother MFC-665CW All-In-One InkJet Printer
Brother mfc -640cm all-in-one inkjet printer
Problem unable to clean4f
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
Unable to cl;ean
Hi Ada,
Go To Below official Brother Printer Video For Your problem,
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-620CN All-In-One InkJet...
Unable o clean4f
Hello, your printhead is damaged, you need to take your mfc to service.
Nov 03, 2013 | Brother MFC-465CN InkJet Printer
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
UNABLE TO INIT. 49 (BROTHER PRINTER MFC-J430W)
dear sir, My printer Brother MFC J430 shows unable to clean 49 in display I have found any solve or suggestion in youtube / Google please suggest me.
email. laskarnet2014@gmail.com
BAHAR LASKAR
SILCHAR, ASSAM
Jun 19, 2012 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-290c print unable 73
hi
try to make hard reset
or download the latest drivers/ program from the site of brother .
some times they apdate automaticaly your programs - and some times it makes problems !!
bernard
http://www.rylwy.com/
Jul 07, 2011 | Brother MFC-290C Multifunction Color...
Clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - suvidha_times@yahoo.co.in
Jul 29, 2010 | Brother MFC-440CN InkJet Printer
Brother mfc 420ch unable to inti
This ia a mechanical problem with the machine. Can be repaired.
Mar 09, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Jan 06, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-665CW All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
