Question about Garden
Parts Diagram For 1999 Oldsmobile intrigue
Front clip
    Sergeant:
  • Garden Expert
  • 417 Answers
This is a forum for chainsaw issues, please find the correct forum that applies to your machine or problem. Thanks!
Posted on Nov 23, 2013
Can u show a diagram on how to bypass ac compressor on a 1999 Oldsmobile Intrigue
If you mean Electrically bypass, simply disconnect the lead to the power clutch. If you mean by pass the serpentine belt? Good luck with that.
Apr 02, 2015 | 1999 Oldsmobile Intrigue
Do you have a diagram of the spark plug firing order for 1999 oldmobile intrigue 3.8 liter
For the 1999 Oldsmobile Intrigue 3.8L:
Firing Order:
1-6-5-4-3-2
Cylinders:
_____(back)____
|...2......4.......6..|
|...1......3.......5..|
.........(front)
Ignition Connections:
(back)
o <--6
o <--3
o <--2
o <--5
o <--4
o <--1
(front)
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Apr 05, 2010 | 1999 Oldsmobile Intrigue
NEED 1999 olds intrigue serpentine belt diagram
1999 OLDSMOBILE INTRIGUE - V6 3.5L 214ci GAS FI N H
Belt Routing Diagram - Multiple Accesory
1999 OLDSMOBILE INTRIGUE - V6 3.8L 231ci GAS FI N K
I hope helps with this (remember rated this help) Good luck.
Dec 23, 2009 | 1999 Oldsmobile Intrigue
Need a diagram of how to put on serpintine belt for a 1999 oldsmobile intrigue 3.5 ltr
Below is the diagram you requested. Thank you for using Fixya and please remember to return to rate this answer.
Greg
99 Intrigue 3.5L Serpentine
Dec 17, 2009 | 1999 Oldsmobile Intrigue
NEED DIAGRAM TO INSTALL BELT
Belt Routing Diagram (Multiple accesory)
Hope helped (remember rated this help). Good luck.
Oct 16, 2009 | 1999 Oldsmobile Intrigue
Diagram for removing a tensioner from 99 Olds Intrigue 3.8
Either in the center of the tension pulley or on the arm that the tension pulley is bolted to there is a square hole that is the size of the square on a 1/2" ratchet. Take a 1/2" ratchet and stick it in that hole and I think most of them you put it in the tighten position and pull on the ratchet. the tension will release and you can remove the belt.
Good Luck
Oct 12, 2009 | 1999 Oldsmobile Intrigue
Drive belt diagram-99 3.5 intrigue
go to any auto parts store and they will print a copy for free.
Jul 02, 2009 | 1999 Oldsmobile Intrigue
LOCATION OF FUEL FILTER ON 1999 OLDSMOBILE INTRIGUE
under the drivers door with a bracket holding the filter on. Be carful some of them have clips holding fuel lines on. might have to tak tank off, but that might lead to a leaking tank,straps a hole lot of mess. Best way is to take off filter, leave off put rubber hose on fuel line and put into a fuel can turn on the key and wait to empty.hope not to much gas in tank.
Feb 22, 2009 | 1999 Oldsmobile Intrigue
Belt diagram
There should be a digram under the hood for the belt .
Jan 11, 2009 | 1999 Oldsmobile Intrigue
Belt replacement
remove your front right tire. remove the black plastic splash cover. loosen the tightening wheel bolt, under to the left, under the fly wheel. make a diagram of the way the belt is or goes before removing, replace belt. tighten the wheel bolt. and start engine.
Dec 03, 2008 | 1999 Oldsmobile Intrigue
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
