Question about Garden
Can the TK carb be switched to a Walbro/Zama
I have a Husqvarna...Code TJ7027D-BC55..I was wanting to know if there is a different carb that I can use on this machine, such as a Walbro/Zama? The one on it now is a TK TZ-11, can not find a carb kit for it, only individual pieces, one of which is $20.
  • 4 Answers
SOURCE: stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Posted on Jul 19, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
rwvanlue
  • 486 Answers
SOURCE: Flooding walbro carb from blower.
The problem centers around the carburetor. The question lies in the condition and operation of the carb initially.
It appears you may need to double check your assembly of diaphragms and gaskets. check for loose welch plugs, adjustment needles in the wrong holes, inlet needle set too high.
*note: metering side diaphragm goes on top of the gasket, fuel pump diahragm has the gasket on top of it.
Posted on Nov 11, 2009
dontbother10
  • 2220 Answers
SOURCE: Primer bulb-carb routing
It should be like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 10, 2010
rycgl
  • 1545 Answers
SOURCE: I HAVE A HUSQVARNA MONDO LINE TRIMMER.WHERE DO THE
For a machine with a remote primer bulb: The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. For a machine with the purge/primer bulb on top of the carb: The small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Oct 26, 2010
I need a carb kit installation guide for my Shindaiwa n452 hedge trimmer
There is no guide. Post the model and manufacturer of te carburetor itself. Walbro, zama, tk, etc.
Sep 20, 2013 | Shindaiwa N452
Need A parts diagram for a Sthil G65 Blower carb.
Unfortunately, Stihl won't release any of their illustrated parts diagrams to anyone except Stihl dealers. The dealers won't release them either. It is possible that the manufacturer of the carb will have a breakdown listed on their site. Stihl primarily uses either zama carbs (www.zamacarb.com) or Walbro carbs (www.walbro.com). Look on the carb for engraved numbers and letters to let you know what series and model to search on. The manufacturer is usually listed either on the bottom diaphragm plate or up on top. Walbro series usually start with a WT, or WA. Zama will usually have a C series (ex. C1U)
Nov 02, 2010 | Garden
How do i repair a choke lever in a weedeater te475y gas trimmer? Does the lever pull straight out of the carburetor.
Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
Here is a parts breakdown for your machine:
http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
Jul 09, 2010 | Husqvarna Garden
What are the factory settings for the "Hi" & "Lo" Carb Jets for the Husqvarna 125L (Weed Trimmer). 1 turn out, 1/2 turn out, etc. Can't get to idle at all, have idle screw all the way in and does...
find L on your carbruetor and turn it clockwise 1/4 turn to see what difference it makes
it should begin to idle by itself?
zama carb. 1 turn out from closed
walbro 1and 1/4 from closed settings are only preliminary
Jun 14, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Can't figure out type of carburetor on my leaf blower.
I have seen 2 different carburetors used on this unit. A Walbro and a Zama. You will need to get the information off the carb. (Walbro WYC-10 or Zama K39A) are the two I have seen, but you need to be sure what yours is. Then purchase the correct O/H kit and rebuild it.
Apr 10, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
