Question about Cell Phones
Radiomobile I have an RM7635USBI car radio/cd player but rear connecting lead to car have gone missing. Can you supply one and, if so, how much ?
  • 518 Answers
SOURCE: car cd player into Fiat punto
Sorry to say, but it it sounds like it's defective. If it's new you should return it for an exchange.
Geno
Posted on Feb 26, 2008
Mike258
  • 1498 Answers
SOURCE: car radio/cd player replacement, wiring problem
Yes. Both leads need to have +12v for the device to function.
Yes. You can run a bypass to the battery to make it work.
Mike
Posted on Jul 21, 2008
micromaster
  • 3614 Answers
SOURCE: Car Radio
what is the exact model / maker, and also the maker of your cd player..
tnx.
Posted on Oct 09, 2008
  • 57 Answers
SOURCE: left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Posted on Jun 01, 2009
SOURCE: bouht Philips car radio CD player at car boot,I've
In most cases the "pink" could either be for an automatic antenna OR remote control unit / The red wire in most cases is to keep the "memory" active on the unit (preset radio stations/clock)....
Posted on Jul 28, 2009
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
Aug 18, 2011 | Pioneer DEH-P4700MP CD Player
Hi All, I have a peugeot 206 and when I enter my four digit code into radio everything OK until I turn off ignition,then I have to input number again.Is there something else I have to do to stop this...
It looks as though the "permanent battery" feed to your radio is missing.
There are 2 battery supplies to your radio ; the main one via the ignition switch that switches the radio on/off and the permanent battery feed that supplies battery to the radio memory.
Check your fuses and connections at the rear of the radio
Apr 03, 2010 | Car Audio & Video
Hi, I Changed car battery on my Toyota Camry '93 and now my CD player/radio doesn't work?
Make sure that you have 12Vdc at the rear of the Radio and at the CD player. If not check the fuses and repalce if necessary. You will also most likely need to enter a 4 to 10 digit code on your radio to get it to work again.
Nov 08, 2009 | Cars & Trucks
Hi my yellow battery lead with the fuse
Are you using AMPs? You may have everything connected right but, when you turn it on the battery doesn't have enough supply to operate the system. This happen to me and I had to change my alternator, and battery.
Oct 24, 2009 | Alpine CDA-9887 CD Player
Cd player
Hello duval00143,
All you need is a 12V power supply. Just connect the car receiver power and accessory leads to the 12V + output and the ground from the receiver to 12V - output. Connect your speakers normally.
Many online electronics parts suppliers have such power supplies. Or you can get one from your local Radio Shack. If you have an old computer somewhere, you can use the power supply from it.
Hope this helps.
Sep 13, 2009 | JVC KD-G210 CD Player
My clarian car stero will play the cd player while
It sounds as if the power leads are not connected properly.
Make sure the memory lead is connected to a constant 12+ volt source, and the switched lead is connected to a 12+ volt power source that is controlled by your ignition switch.
Aduz
Feb 24, 2009 | Car Audio & Video
I have a sony cd player for my car. everytime i turn the engine off, the pre set radio stations are wiped. what can the problem be?
Its problem of connections. find yellow wire in player's rear connector and hook it always 12 volt as its supply to memory of player.
Sep 11, 2008 | Sony Car Audio & Video
Subwoofers not working While listening to CD
The remote turn on lead for the subwoofer amplifier has been connected to the power antenna lead (solid blue) of the radio. It just needs to be connected to the radios amplifier turn on lead (blue with white stripe).
Jun 14, 2008 | Kenwood DNX7100 Car Video Player
Sound problem
sounds like you have the antenna wire connected to the power amplifer lead in the car.
Go behind the radio, there is a solid blue wire that will be connected to a wire in the car, take the solid blue wire off, and connect the blue/white from the radio to where the solid blue was originally connected. This should solve your problem
Nov 24, 2007 | Jensen VM9410 Car DVD Player
Sony cdx mp70
It may be that the remote lead on the amp has been connected to the auto antenna lead on the radio instead of the amp remote lead and because the auto antenna goes down when the cd is inserted it is turning off you amplifier, check the connections behind the radio or if there is a light on the amp check if the light goes out when you insert a cd
Oct 05, 2007 | Sony CDX-MP70 CD Player
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
