Question about Samsung AS18A6RB Air Conditioner
Emergency heat not working where is the heating elements located
  • 739 Answers
User manual:
javascript:openreq('http://downloadcenter.samsung.com/content/UM/200305/20030520185350656_AS18A2RE.pdf')
if you are using a hard wired thermostat, you have one designed for a heat pump. Heat pumps are minimally effective at outdoor temperatures below 30'f. Emergency heat systems are not generally included with any split system, but would be located in the indoor air handler.
Posted on Nov 20, 2013
I have a 1800 pioneer heat pump after about 10 minutes it switches to EC I have to go to my panel and a witch it back on Why?
Emergency heating via heat elements will only run till temps get to a certain point then the elements turn off and the heart pump takes over and that is the economy setting. Emergency heat is used to quickly raise temps then heat pump takes over. The elements are very expensive to power ergo the switchover.
Aug 29, 2017 | Pool & Spa
I have a thermostat RTH9580. Why do I have emergency heat under system AND heat which sometines switch automatically to auxilliary heat?
If you have an air to air heat pump, in colder temperatures, the heat pump will not heat as well as it would in warmer outdoor temperatures making it run longer. the digital thermostats work off of a built in algorithm that kicks on the auxiliary heat when the heat pump runs to long so that it will satisfy the thermostat quicker. This can be tied to the Emergency heat @ the thermostat energizing a few heating elements, or just energizing a separate element from the emergency heat. I always recommend on an air to air heat pump to run the emergency heat when you have consistent Outdoor temperatures below 20 degrees F because you will cycle the heat less by getting hotter heat making life more comfortable, and it costs about the same as running the heat pump since @ those temperatures, it will run all the time.
Jan 09, 2015 | Honeywell 7 Day Touch Screen Programmable...
Why doesn't the compressor start in the heat mode
If the compressor is off and the heat coil is on - this is normal for the "E" or emergency heat setting. Check for proper connections between the Heat-pump, furnace(heat source) and the thermostat and that the thermostat is capable of controlling a heat-pump with secondary/emergency heat units. Thermostats designed for this have 4 settings: Cool / off / heat / E(emergency heat). in the "heat" setting, both the Heat-pump and Aux heat work together to maintain temperature. In the "E" setting, only the Aux heat source is used. The "E" setting should only be used in extreme cold - when the Heat-pump can no longer produce heat.
Sep 10, 2014 | LG LP153HD3A - 14,300 BTU, R410A, 9.4 EER,...
RUDD Model UBHC-21J18SFA: Emergency heat not automatically engaging. Used to work, now I must manually turn the thermostat to "Emergency Heat" to get the elements to engage. What's broken?
Sounds like your Auxillary heat is out (the element that is energized when an air to air heat pump can't keep up with the thermostat setpoints).
Jan 30, 2014 | Heating & Cooling
I JUST BOUGHT THIS UNIT IT HAS THE OUTSIDE UNIT AND THE INSIDE UNIT AND I WAS TOLD THAT THE HEAT PACKS IN THE INSIDE HANDLER IS FOR EMERGENCY HEAT ONLY...IS THIS TRUE?
Yes, if you are talking about a heat pump. It you have an electric furnace inside, the electric elements are for emergency heat. Otherwise, unless you switch it manually at the thermostat, the heatpump (outdoor unit) will run all year around. If you want to use your inside heater (electric heater) just switch your thermostat to "emergency heat" and it will turn on the electrical elements instead of the outdoor unit. This way will make your elec. bill higher tho. The heat pump is much more efficient. Hope this helps you , have good day
Jul 21, 2011 | Goodman Heating & Cooling
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Jan 11, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
Amana Heat Pump Emergency Heat will not come on
the problem sounds like 1 or 2 things either you have a bad sequencer for the heat strip or the emergency heat portion was not wired up.
Jan 30, 2009 | Amana PTH123B25AJ Heat Pump Air...
Samsung AS18A6RB Air Conditioner Logo
128 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
