Question about Microsoft Xbox 360 Console
Xbox 360 s keeps freezing
All profiles disappeared aswell as all other info and freezes as soon as it's turned on
    Sergeant:
  • 199 Answers
Your hard drive is failing or your getting whats called RROD, very common on the xbox. Try to start your xbox with out your hard drive. If it start then your hard drive need to be changed.
Posted on Nov 20, 2013
3 Suggested Answers
SOURCE: Xbox 360 freezes and Dotted Lines Appear
hi
my xbox has the same problem as above, also we have three red lights on console is there a solution?
xbox live :leighjay
Posted on Feb 19, 2009
  • 27 Answers
SOURCE: My xbox 360 beeps then freezes to random screens
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heatguns and work just as good. the last thing you need is Artic Silver 5 which can be found for 5 bucks on ebay. now once you have this you need to lay your motherboard on a flat imflammable area. light the torch and make shure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top ofthe chips are cleaned with a paper towl of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to ajust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small srewdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
THIS WILL REPAIR 3RED LIGHTS,FREEZING,NO VIDEO, 2 red LIGHTS. in most cases 1 RED LIGHT will be fixed
GO TO A HAREWARE STORE FIND THE FOLLOWING THINGS IF YOU DONT HAVE THEM
16 platic washers
8 metal washers(make shure all the washers fit snuggly around the screws and are very thin)
8 screws about an inch long that fit heat sinks
Butane blow torch, just a small one will do
small torx wrench kit. big and small flat and phillips head screwdrivers
Posted on Feb 21, 2009
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
I bought crackdown on the xbox live game marketplace but it keeps freezing in the beginning when it says signing in to gamer profile
Go into your settings menu on your 360, and erase crackdown from your hard drive, then re-download. This should correct the problem.
Sep 03, 2012 | Microsoft Crackdown for Xbox 360
My xbox 360 is starting but soon as it gets to dashboard the screen freezes?
my xbox 360 is starting but soon as it gets to dashboard the screen freezes?
Nov 19, 2010 | Microsoft Xbox 360 Console
Xbox 360 when i press guide button on controller allways freezes,cant create profile freezes,as soon as i go to clock on dash freezes,when i click on initial setup does nothing keeps blinking wont enter...
Resetting to factory defaults / resetting parental locks
Press the following key combination
Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
Aug 22, 2010 | Microsoft Xbox 360 Console
I have been playing star ocean the last hope and now my xbox 360 freezes constantly. Help! I deleted and reloaded the game and it still freezes. I thought it was the game but now Oblivion is freezing too.
The reason why your Xbox 360 keeps on freezing is because you will soon encounter the red ring of death or the E74 error. to simply solve this error check out this vid
Apr 19, 2010 | Microsoft Xbox 360 Console
Band hero cant get it to work on 360 keeps freezing but soon as i put it any other game its fine just that game any1 else have this problem. its happened to me b4 with nhl 2010 to a while back. the main...
TRy the game in other consoles if the game keeps playing up its the game, it may have corrupt data, otherwise you r xbox may just not like the game. Good Luck.
Nov 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 freezes instantly
You can check out the article atezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369for moreinformation on fixing freezing problem of your xbox 360
Jan 07, 2009 | Microsoft Xbox 360 Console
Freezing
he game console heats up during use, and given enough time, the temperature inside can reach very high levels due to insufficient cooling. An overheated Xbox 360 is indicated by both left quadrants lighting up red. Because of the way the Xbox 360 is constructed, this may result in stresses building up between the delicate
Dec 21, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
