Question about Zebra GX420t Thermal Printer
Won't print err01 on labels
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
Aug 19, 2011 | Dymo LabelWriter Thermal Printer
We removed a stuck on label, now the printer won't print half the thermal label
I haven't seen one of these for years. However I really need more detail. In what direction is the print missing? across or down the label?
If across it most likely a dirty printhead
If down the label it could be a portion of label still stuck to the sensor.
Can you describe where the label stuck?
Aug 19, 2011 | Datamax Prodigy Plus Thermal Printer
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
My Brady LabPal label printer seems to be printing labels that are not very bold and, in fact, the numbers are often only half printed. Do I need to change the ink cartridge within it, or what is the...
I have label cartridge in but it doesn't print, just says "insert labels". I have tried many times to take cartridge out, and reinsert, but it won't do anything.
Jul 01, 2010 | Brady LAB PAL Thermal Label Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
Oct 14, 2009 | Zebra TLP 2824 Printer
HL-2030 printer won`t print labels with Word 2007
If it's the same as my Hl-5250DN, you have to use MP Tray mode. The MP (multi-purpose) tray is cleverly hidden on the front of my printer.
Feb 01, 2009 | Brother HL-2040 Laser Printer
Dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
May 24, 2008 | Dymo LabelWriter 400 Thermal Printer
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra GX420t Thermal Printer Logo
53 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
