Question about Samsung DV220AGW Dryer
Dv328agw xaa - Samsung DV220AGW Dryer
Samsung Gas Dryer model DV328AGW/XAA, not getting gas to ignighter,
Could be a defective igniter, thermocouple, or gas valve
Mar 06, 2017 | Samsung Dryers
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
How to change the belt
try the door safety switch or the lid switch...adjust the timer control.......
Aug 20, 2012 | Samsung SM-DV328AGW - SERVICE MANUAL
Samsung dryer will not spin.
you must check the timer might not have contact in the terminal although it was starting to count. then you check if their is a voltage that is coming from the motor, and check weather the starting capacitor has resistance or worn out.
Aug 16, 2012 | Dryers
My mp3 player is lost the os
You did not give all the infomation on the MP3 player so all I can do is guide you to the correct page to download your needed download.
The following MP3 players are listed there:
YP-Z5AP/XAA
YP-Z5AS/XAA
YP-Z5QB/XAA
YP-Z5QP/XAA
YP-Z5QS/XAA
YP-Z5ZB/XAA
Please rate me
Go to this website for your download... http://www.samsung.com/us/support/#
Jan 15, 2011 | Samsung YP-Z5 MP3 Player
DV328AGW Samsung dryer...sensor dry doesn't seem to work.
Put some Windex on those sensors. They may have a barrier of junk on them preventing the sensors from detecting dampness.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 17, 2010 | Samsung DV328AG Gas Dryer
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung DV220AGW Dryer Logo
20 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
