Breadman TR777C Bread Maker Logo
G
Gaby Posted on Nov 19, 2013
I was doing bread without any problem yesterday, today not even the light goes on! Also I think I smell a smoke odor before but wasn't thinking oils be from it.
I have honda generator,overhauled last year,last week i changed oil from then onward oil level is getting low but not that low . with white smoke at the start of generator and oil burning smell.
Could be the engine, until the overhaul, was run on a low grade or low specification oil that allowed or even encouraged sludge and carbon to build up in the engine.
If a high detergent oil was used at the overhaul it would have scoured the inside of the engine, removing deposits so increased oil consumption is often the result.
The additive packs of some oils also tend to cause the premature hardening and failure of some types of rubber seal, though this was a huge problem 20-30 years ago it isn't seen much today.
2answers
I just purchased a Black and Decker electric (cord) mower used. It worked fine yesterday but today, a burning smell and smoke came from engine. Is this a fatal flaw or common?
If you purchased your Black & Decker yesterday and it smells "burning". so it's burning inside; don't even think it twice and return it to the shop where you bought it and CLAIM that they should change it or return your money. Don't accept that it should be "repaired"!!! I bet they sold you a typical cheap garbage assembled in some of those far east countries where quality doesn't matter.
Aug 27, 2015 • Garden
Mitsibushi pajero oil light time
White SWEET smelling smoke, or white OILY smelling smoke? If it's white thick SWEET smelling smoke, you have a blown head gasket - that's the smell of antifreeze burning in the engine, which it should NEVER do. If it's white OILY smelling smoke (smells a lot like diesel), then you're getting too much fuel into the cylinders.
If it's sweet-smelling smoke (antifreeze), pull the oil dipstick & check the oil level. If the oil level is HIGH and the oil looks like a mocha milkshake, that's absolutely conclusive - that's what happens when antifreeze gets into your oil, and it's nasty corrosive to engine parts.
I'm not at all surprised that the oil light is on if it won't start - you won't get much oil pressure until the engine is running.
Lawn Boy 10641
see if the oil smells like gas the carb maybe sticking and gas gets into the oil washing the oil out this will make hard starting and smoke if so the needle valve is not sealing if you caught in time without major engine damage a sign is the oil being over full and smelling like gas
I have a problem with an older model (?) Kitchenaid side by side BUILT-IN refrigerator/freezer. There is a perasive odor (like toxic fumes...a pungent, rather a medicated odor that is extremely noticeable...
refrigerant doesnt have a smell hmm only thing I can think off try to look at the light at the top of the fridge did it melt the liner or plastic cause its a common problem with very strong toxic smell
5helpful
Oil light flickers...
replace the oil pressure sending unit
Smoking skyhawk
If the smell of the white smoke is sweet, it is coolant and most likely a head gasket failure.
2answers
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
2answers
Flashing dash lights
if it runs ok leave well alone the smell will linger for long long time though ,open a window
Top Breadman Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
