Question about Zyxel P-334WT (P334WT) Firewall
Cannot connected to my router
I went to the remote management section, i checked one of the box which has the word "all" in it. after, the router restarted and i cannot log in to my router again. i am using window vista, and it said "this is caused by two computer's firewall are activated, result that 'http' is banned. it also said that the computer has already allow the entry but was stopped by the firewall from the other side." please help me get out of this trouble, this is really irritating. my internet is still fine. but i cannot go to my router. HELP!! this will be really appreciated!! THANK YOU!!
    Scholar:
  • 193 Answers
Once u went to teh remote login u can see port and u need to change it to 8080 and reboot the router and try
Posted on Oct 17, 2007
SOURCE:
How do I install a VPN on my Linksys WRT350N router?
->Open a web browser on your computer and log in to the router.
->Click on the "VPN" link of the router's control panel.
->Select the "Enable" option for "This Tunnel" and select the "Any" options for the "Remote Secure Group" and "Remote Security Gateway" sections. Select the "Auto (IKE)" Key Management method as well.
->Enter a "Pre-Shared Key" of a length of at least 8 characters or more. This is the key you use when you connect to your Linksys VPN at a later time.
->Click the "Apply" button and your Linksys VPN is set up.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 16, 2012 | Linksys WRT350N Wireless Router
My dlink dir 300 was working fine with our 2 laptops. i bought a blackberry phone and tried to set up wifi connections. blackberry phone asked me to enter some nos. for the router. so i did. then our...
1. Restart the router by plugging it off and back on
Try to connect again
If that does not work,
go to the router's configuration page
Make sure you have DHCP enabled to assign ip addresses
Also on the devices, check to have Wi-fi turned on, and iP address to be configured automatically.
Please check and provide feedback
Regards,
Katharsys
Mar 07, 2011 | D-Link DIR-300 Wireless Router
Cannot access remote management of WRT160N Router at all.
did you changed the Remote Management Web Interface to use a different port other than port 80? some defaults to use 8080. So in your case, try this address in IE: http://10.0.0.250:8080
Apr 11, 2009 | Linksys WRT160N Wireless Router
Security code for Linksys router
Many Windows XP users have home networks which utilize a router which allows several computers to share the same Internet connection. It is important to know that perimeter security is just as important as keeping your PC locked down. Doing so will prevent successful attacks from the outside world. This article covers how to secure a Linksys WRT54G router.
Here are the step-by-step instructions:
  1. Log in to your router by opening your web browser and going to http://192.168.1.1 - this is the address to acces your router. If this is your first time logging in, leave the username field blank and enter 'admin' (without the quote marks of course) as the password.
  2. The first thing to do is back up your current configuration. This way if you set something incorrectly you can always revert back to the original setup. Click the "Administration" tab.
  3. Click "Config Management"
  4. Click the "Backup" button. Choose a location to save your configuration where you will remember.
  5. Click "Management"
  6. If you have not yet created your own router password you will need to do this now. If you have, please skip to step 11.
  7. Next, where it says "Router Password:" enter a new password into the text field.
  8. Enter the password again in the box that says "Re-enter to confirm:".
  9. Then, Click the "Save Settings" button. and wait for the confirmation page.
  10. Click the "Continue" button. From now on when you log in you will need to enter 'admin' as the username and use your new password.
  11. Click the "Security" tab.
  12. Where it says "Firewall Protection:" tick the box that says "Enable" if it is not already selected.
  13. Place a check mark next to the box where it says "Block Anonymous Internet Requests"
  14. Place a check mark next to the box where it says "Filter Multicast"
  15. Place a check mark next to the box where it says "Filter Internet NAT Redirection"
  16. Place a check mark next to the box where it says "Filter IDENT(Port 113)"
  17. Click the "Save Settings" button and wait for the confirmation page.
  18. Click the "Continue" button.
  19. If you are not using your router for incoming http (web) connections, it is a good idea to turn off remote admin. Click the "Administration" tab again. Where it says "Remote Management:" tick the box that says "Disable" if it is not already selected.
  20. Click the "Save Settings" button and wait for the confirmation page.
  21. Click the "Continue" button.
  22. Sometimes disabling this does not work, so to make sure, click "Applications & Gaming"
  23. In the first available slot under the "Application" column, enter "Security".
  24. In the same row, under the "Start" column, enter the number 80.
  25. Enter 80 again in the adjacent box to the right under "End".
  26. For the "Protocol" select "TCP".
  27. Under "IP Address" enter the number 254.
  28. Check the "Enable" box for this entry.
  29. Click the "Save Settings" button and wait for the confirmation page.
  30. Click the "Continue" button. This will divert all incoming connections for web access to the router to a non-existant host. This reduces the chance of a break-in from a nosy outsider.
Mar 18, 2009 | Linksys Wireless-G WRT54GS Router...
Can't connect to Desktop PC with Dameware using Netgear Router
Hi brianaugusti,
You need to open a port in the new router to allow remote connection. The port used by dameware is 6129, and the windows remote port is 3389
Please provide the model of your router so I can assist you with the next steps and how to open the ports.
Jan 09, 2009 | DameWare NT Utilities
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp://192.168.0.1 to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Name=VNC
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to http://10.0.57.46:5800
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the 194.145.183.83 is the IP address of your office, this should work. Be sure you apply a password or anyone going to http://10.0.57.46 will have access to you router, I also recommend changing the port from 80 to 8080 so that http://10.0.57.46:8080 has to be typed to access the remote management interface.
Jan 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Hampton Bay Ceiling fan
The replacement remote will work fine. All you have to watch out for is that the remote receiver and the remote transmitter are a matched set.
Jul 21, 2008 | Universal Remote Control Hampton Bay...
WIreless card not connecting
Go to the device manager on your computer(one with wireless card) and install the wireless card with all of its drivers. Then try to connect.
Apr 03, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Zyxel P-334WT (P334WT) Firewall Logo
122 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
