Question about Whirlpool Dryers
Install shipping bolts model GHW9150PWD - Whirlpool Dryers
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
This dryer has none
Posted on Nov 22, 2013
What does error code F7 E1 mean on a whirlpool VMW washing machine
This code indicates a motor speed sensing error, the motor can not achieve the correct speed for the cycle selection.
Have the shipping bolts been removed?
This error code indicates that the motor is having difficulty turning.
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See your Installation Instructions for details on how to remove the shipping bolts.
Dec 27, 2016 | Whirlpool Washing Machines
F7 on my hot point. Washing machine
Are the shipping bolts removed?
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See the Installation Instructions for details; find them by entering your model number in the search tool below.
Were you washing a very large load?
The washer may be overloaded for the cycle you are running. Remove a few items from the load. See the Cycle Guide in the Use and Care guide for loading suggestions for each cycle.
To remove the error display, press Power once. Then press Power again to restart the washer.
If pressing Power does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Apr 22, 2015 | Washing Machines
FOUR BOLTS AND RUBBER WASHER ON BACK OF WASHING MACHINE DO THEY NEED TO BE REMOVED BEFORE OPERATION
Hi Jamie, thank you for your inquiry! It seems like you are referring to the shipping material. This consists of 4 shipping bolts, 4 spacers, 1 metal "P" clamp, and 2 hose clips. Yes, according to the installation manual for the model number posted above, GLTF2940ES, this material must be removed. I have attached the Installation Instructions on how to do so. I hope this information helps to some degree. If you have further questions, please do not hesitate to reconnect.
Aug 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Need to have a list of Maytag Front Load Waher Model #s that do not require shipping bolts.
all washers ever made regardless of front or top load need shipping support when shipped be it shipping bolts or other means of synching the tub down so it doesnt become damaged by bouncing around in the back of a truck
Jul 21, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Where are the shipping pins on a centennial 300
The installation instructions are here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%20W10200890.pdf
From looking on pages 4 - 8 of the manual there are no shipping pins. There are 20 steps to the installation procedures and none of them include the removeal of any shipping pins.
However... that being said if there are any shipping bolts it is usually ONE bolt in the back of the machine near the bottom of the tub carriage on SOME machines. It does not appear that this particular washer has one.
Thanks for choosing FixYa.
Kelly
Sep 26, 2010 | Maytag Washing Machines
Where to get shipping bolts for wssh300g1ww
Hi Judy
Your best bet would be calling GE and see if there is a part number for those bolts and where you can get those.. Installer usually throw those away after installation..
Here is their tel #1 800 626 2000
Jun 29, 2017 | GE Washing Machines
Where to get shipping bolts and how to install them?
DEPENDING ON WHEN YOU MOVE TRY www.repairclinic.com LOOK FOR ITEM NUMBER 912239 USING THE MODEL NUMBER YOU POSTED
Apr 07, 2009 | GE WSXH208A Front Load Washer
Front load washer
Usually, the problem with frontloaders shaking violently is that shipping materials are still in them (even if you've paid someone to install them). Generally on frigidaire models they have two sets of shipping materials. The first set is a set of 4 shipping bolts on the back panel. After removeing these, on some models, you also have to remove the lower front panel by taking out the screws. On a few of the models you will find 2 yellow metal bars connected to the bottom of the washer and the bottom of the tub. After removing both sets of shipping materials, make sure not only is your unit level, but all feet are firmly on the floor and locked into place. Your machine should have come with a set of instalation instructions that will run you through these steps more clearly, but if you don't have them or are still having trouble, just reply back to me.
Jun 26, 2008 | Frigidaire Washing Machines
Shipping bolts for Maytag Neptune
There is a product call LITKIT TM, it is a universal shipping kit for washing machines. www.litco.com
May 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Shipping bolt installation
A total of four shipping bolts need to be installed: two longer ones on the bottom and two shorter ones on the top. Each shipping bolt consists of a metal screw inside a plastic cylinder which fits between the washer suspension and the back of the washer cabinet. The metal screw pulls the washer suspension against the plastic cylinder which, in turn, is pulled against the rear cabinet, thereby securing the suspension against the back of the cabinet. The Whirlpool part number is 285955. These bolts can be ordered from various suppliers for $20 - $30. To install these bolts, you will need a 13 mm wrench and a flashlight so you can see where the bolts screw into on the washer suspension.
The procedure is as follows:
1. On the back of the washer, remove the 4 plastic covers over the oblong shipping bolt holes. Carefully pack these covers with the water and drain hoses as they will be needed when the washer is re-installed in its new location.
2. Using the flashlight as a visual aid, look inside the oblong holes and identify the area on the washer suspension into which the shipping bolts screw. It is a white plastic part that is not directly behind the the shipping bolt holes, but is slightly above that level.
3.Look at the shipping bolts. The bolts described above (Part number 285955) have a a plastic arm at one end . This arm must be sawed-off for installation on older machines. You will have to determine whether or not the arm needs to be removed.
4. Starting with the bottom two holes, carefully slide a shipping bolt through the hole toward the front of the machine. Angle the bolt upward toward the screw mating hole, and carefully guide the bolt into the hole. Use the 13 mm wrench to engage the bolt into the mating hole.
5. Make sure that the plastic end of the bolt is closely seated against the back of the washer cabinet. Using the 13 mm wrench, screw in the lower two bolts, but do not tighten at this time.
6. Repeat steps 4 and 5 for the upper two shipping bolts.
7. After the plastic part of all 4 bolts has been firmly seated against the back of the washer cabinet, carefully tighten all 4 bolts.
8. Go to the front of the washer and push on the drum. The drum will rotate but it should not rock. If that is the case, then you are done.
Feb 29, 2008 | Washing Machines
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
