Question about Remington Garden
Broken driver gear and interivaal - Remington Garden
    Sergeant:
  • 417 Answers
Can you include a picture because most saws do not have any "driver gear" or "interivaal" (what exactly is an "intervaal?")
Posted on Nov 23, 2013
My macita imp li-ion 18v chuck slipps
You may have a broken gear in the gear box or a broken output shaft. In either case you need to have it repaired or replaced.
Jan 21, 2015 | Drills
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
97 nissan quest will not move when in gear and the vehicle is rolling freely when in park. ....suggestions? Grinding sound when in gear and the drive shift on the driver side is spinning free
Well, there's a Pin that holds the transmission gears in place when you've got the car in park. This Pin blocks the gearbox from moving... either the pin isn't fully engaging the gearbox, or it's just broken.
If it's not engaging, it's just a question of adjusting the shifter linkage. That can be fixed relatively quickly.
However, the accompanying grinding sounds really make it sound like it's broken.
Jun 24, 2014 | Cars & Trucks
Driver side window will not come up. motor is working but window will not come up
the window regulator has probably broken or the gear has stripped inside the motor. pull the door trim off and see if the wire from the regulator is still conected and tight, if its loose then its probably broken and will need replacing, if it looks tight then try and pull the motor off the window reg and check the regulator drive gear. hope this helps. cheers.
Jun 03, 2011 | Nissan Maxima Cars & Trucks
A6 very low dipped beam
This may be caused by the adjuster on the back of the headlight. There are adjuster that can be turned using a phillips screw driver. The adjusters then turn a bevel gear and that turns the shaft that adjusts the up and down, left and right on the light. Sometimes these gears get damaged or broken. If the gear is broken you will not be able to adjust the alignment of the light. You can purchase the enclosure on line but they are very expensive. I hope you get lucky and just need to have them adjusted
Feb 15, 2010 | 2001 Audi A6
I HAVE TWO BROKEN MAKITA lxtbhp 351 z DRILLS. i
yes it is possible but you may find both gear boxs have gone in the same place it is a common problem with this drill gear box is £66
Oct 25, 2009 | Makita Drills
The rollers, where the paper jam is on the inside. The paper will feed from the both tray and from the side feed but will jam just before these black rollers.
It could be one of a few things... You may have a small piece of paper jamed in the fixing unit or you may have a broken driver gear for the fusing unit.. If you do not see the fixing rollers turning and it is making a noise, the gear most likely is broken.
Aug 16, 2009 | Office Equipment & Supplies
Poping noise in the 1rst gear. all other gears seem fine
If you hear a loud clicking noise when riding at 5mph and slowly accelerating to 25mph, you have a broken tooth on first gear. The pressure that broke the gear tooth was present on the gear that it meshes with. Both gears must be replaced. If only the known broken gear is replaced you will need to do the repair all over again 10 minutes after completing the first repair because the meshing gear will loose it's weakened tooth. In this case I believe the meshing gear is actually the main shaft. I don't have a gear shift pattern diagram for your bike but when the gearbox is opened up the meshing gear will be obvious.
The entire engine gets completely torn down. Not recommended for the novice mechanic. Flywheel puller, torque wrench, impact driver and case splitter required. I would install new crank bearings and seals (at least do the seals) and a new drive axle bearing and seal at the sprocket end. Now is the time to do it while the engine is already apart.
A “very helpful” rating for this answer? Thanks!
Jun 26, 2009 | 2002 Yamaha TT-R 125
Garden Logo
22 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
