Question about Huawei M835 MetroPcs Cdma
When i turn on my wifi on my huawei m835 it says "unable to scan for networks" and the wifi automatically turns off.
Wifi turns off when it says it is unable to scan for networks
5 Suggested Answers
allinallelec
  • 407 Answers
SOURCE: My Huawei M835 is bricked
flash software your mobile.
Posted on May 29, 2012
guatemalt46
  • 33 Answers
SOURCE: how to repair the charger port on a huawei m835 android
replace the motherboard thats the only way you can repair the charging port. its attached on to it not as a removable piece.
Posted on Dec 13, 2012
  • 425 Answers
SOURCE: how do i fix the wifi not turning on , on the huawei m931
its in airplane mode take off airplane mode and it should give you wifi back
Posted on Feb 01, 2015
Ngoro
  • 1144 Answers
SOURCE: HOW TO INSERT SIM CARD TO HUAWEI M835
Huawei M835 is a CDMA phone - have no SIM card slot.
Posted on Apr 29, 2015
Huawei m835 manual
Hi Mickie.
see if this link will help you out for your manual.
Huawei Cell Phones Huawei m835 manual Google Search
Nov 03, 2017 | Huawei Cell Phones
Carnt access wifi it keeps saying unable to scan
Try Turn mobile network off. WiFi should work
Oct 13, 2016 | Cell Phones
WEAR IS SIM CARD SLOT FOR HUAWEI M 835
1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
Apr 29, 2015 | Huawei Cell Phones
How to unbrick a android huawei835
This How To UNbrick your huawei m835 phone step by step.
To tell if your phone is bricked it should only show just the huawei logo or the android logo when you try turn it on and no key combination works to boot into recovery, if u can boot into recovery, dont use this guide.
1) Click This Link to download Huaweis Oringinal Software. ---->HUAWEI M835 - Huawei Device Co., Ltd..
a)Click on the software tab and select the first file there. It may or may not show an error but dont worry just refresh the page and the download will start.
2)When its done, open the M860V100R001C153B251SP03 folder (the folder you just downloaded).You should see another folder called dload and some instructions.If you dont understand what im saying then click the instructions in the folder.
3)Connect your SD card NOT your m835 phone into the computer.
4)Then drag the dload folder any were on the SD card.
5)When thats done take out your battery and put it back in.
6)Press and hold Volume Up + End Call + And The power button at the same time.(i know this sounds wrong but it works)
7)Its Gonna Update your firmware.
8)When its done Turn On your device and the screen that popped up when you first got your phone should appear.
9)Continue with that and BAM your phone is now UNbricked.
Oct 11, 2012 | Generic Huawei M835 M-835 Solid Black...
My Huawei M835 wont connect to WI-Fi networks.
Enter setup - - - - - - - - - - - - mobile network access point name - - - - - - - - - - - - - - the function key reset to default ....then ok...
Gel cover
Sep 11, 2012 | Generic Huawei M835 M-835 Solid Black...
I have an huawei m835 i tried hooking up my wifi but when scanning for a second it tells me that its unable to search for networks
try doing a factory reset..hold the home button down while the phone is offf,,then with out releseing the home button press and hold the power button
Aug 11, 2012 | Cell Phones
My wifi is unable to search for networks what do i do?
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 11, 2012 | Huawei M835 Ideos
How do i master reset my m835 huawei metro pcs phone
WITH PHONE OFF PRESS THE VOLUME UP BUTTON AND GREEN CALL BUTTON AT THE SAME THEN PRESS AND RELEASE THE POWER BUTTON ONCE IT TURNS ON RESET MENU WILL POP UP
Jun 26, 2012 | Huawei M835 Ideos
How to remove battery from huawei m835
To remove battery from Huawei m835,
Turn the back of the phone, remove the outer covering(casing),
put your hand in the space provided to lift the battery and the battery is out.
Sep 14, 2011 | Cell Phones
Huawei M835 MetroPcs Cdma Logo
Top Huawei Cameras Experts
sandrasteven
JonSnell Electronic
JonSnell Electronic
Tony Parsons
Tony Parsons
Are you a Huawei Camera Expert? Answer questions, earn points and help others
