Question about Montgomery Ward Ginnys Brand 10-Speed Blender - Denim
Ginnys 10 speed blender won't turn on - Montgomery Ward Ginnys Brand 10-Speed Blender - Denim
How do I locate a manual for a Ginny's soup blender
Go to where you bought it and ask for help or if you know the manufacturer address phone or send a request letter.
Sep 12, 2014 | Montgomery Ward Ginnys Brand Soup Blender
What is the weight and size of this blender?
The Hamilton Beach Wave Crusher 8 Speed Blender 1 EA58142 weighs 9 pounds and measures 8 x 10 x 16 (LxWxH).
Feb 07, 2013 | Hamilton Beach Wave Crusher 8 Speed...
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
Kitchenaid ksb560 won't turn on. No power at all...
Take the base off and check the motor for continuity.
Jan 08, 2012 | KitchenAid KSB560 5 Speed Blender
Does the white plastic base bottom of the glass blender come off for cleaning or is it attached permanently
Yes the white plastic base comes off. There are several model of the BL10450; here are the Instructions which contains an illustration of the assembly:
https://www.unitycart.com/pjss/parts/parts_classic.asp
See the notes on Blender Jar Assembly. It turns on clockwise; off would be counter clockwise.
Mar 07, 2011 | Black & Decker BL10450 10 Speed Blender
Where to buy glass jar for my osterizer pulse matic blender 10 speed
Try "The Gourmet Depot" website or search "small appliance parts" and find a site that carries the Oster blender part. You will need the model # of the blender.
May 20, 2010 | Oster 006832000000 10Speed Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Problems with Oster 4172 10 Speed Blender
Most probably find a Oster 4172 manual here. Just send them a search request.
Feb 18, 2009 | Oster 4172 10 Speed Blender
Health master 100 jammed gears in blender container
no but figures you dont actually give free help.....its all about the almighty dollar..
Peace
Nov 11, 2008 | Jack Lalanne Health Master 100 8-Speed...
Montgomery Ward Ginnys Brand 10-Speed Blender - Denim Logo
50 people viewed this question
Top Montgomery Ward Blenders Experts
eyecam
Ross Keen
Are you a Montgomery Ward Blender Expert? Answer questions, earn points and help others
