Question about HP Mini 1000 Netbook
How to boot from external source usb - HP Mini 1000 Netbook
    Top Expert:
  • HP Master
  • 22,768 Answers
In the bios, set USB as first boot device.
Posted on Nov 19, 2013
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
I have a samsung sens R20 laptop,when i boot it no display in monitor
REMOVE all media, DVDs/CDs, USBs...etc. Can you do a system restore/recovery by reboot , when the boot starts immediatly start tapping F-4 repeatly to load system restore/recovery.
Nov 12, 2012 | Computers & Internet
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
When I start up computer all I get is black screen with a blinking cursor in the top left hand corner...how do I fix this so it will load properly
how long have you let it try to boot when you get the _ flashing. also if you have your computer to set up from a usb drive make sure you have disconnected all usb drives and other peripherals just to be certain it's not trying to boot from an external source.
May 08, 2012 | Computers & Internet
WD elements hard-drive not working, powering up fine + PC is making the noise associated with a USB port connecting to an external source, but the Hard-drive is not showing up on My Computer and is...
Try on any other computer first.
Download Hirens Boot. Place burned CD and reboot with it. Run Norton Ghost (bundled with Hirens Boot) and select USB option. Do a disk check.
Mar 06, 2011 | Western Digital Elements powered by WD 320...
Can't boot from a usb flash drive using ASUS A8S-X motherboard.
Have you changed the boot menu in the bios to accommodate an external source?
Apr 18, 2010 | ASUS A8S-X Motherboard
Toshiba Tecra A3X Not Booting from USB CD ROM
Your laptop is apparently unable to boot up off an external usb source. Only newer equipment has this provision in the bios. Since you cannot boot up from usb the only way you can recover your unit or do a clean reinstall or repair of xp is to replace the internal drive that is allegedly defective.
Replacing the optical drive is fairly easy and does not involve massive disassembly of your laptop. And any cheap drive will work provided it has the same physical configuration as the old one.
Jul 03, 2009 | Toshiba Tecra A3 Notebook
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
HP Mini 1000  Netbook Logo
37 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
