Question about Lincoln Pro Cut 55
Need a manual
Is there a manual on how to use a Lincoln pro cut 55
2 Suggested Answers
rujoking
SOURCE: My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
(From: https://app.aws.org/forum/topic_show.pl?tid=31328)
"Remember, they are a drag machine up to about 3/8" thick material. Keep the power down as low as possible for the material being cut. Keep the right air filters on to supply clean air. Keep the air pressure between 60 (min or it will shut down) and 70 for most applications (more is not better-just like oxygen on the torch or air to an air-arc).
Also, check that the air hose hasn't come loose from the gun.
That was Brian's problem from YouTube (http://www.fixya.com/answer/answerpageslideview.aspx?thid=26182813&ctg=373&brd=5236)
Posted on May 02, 2016
Pro Cut 25. Plug power in and power on, seems fine. Plug air hose on and safety light comes on immediately and will not function at all. Any ideas?
Page 25 of this says that the 'consumables are not properly installed.' If they are properly installed cycling the power will allow you to resume.
Lincoln Electric IM665 PRO CUT 25 Manual Page 25
Dec 25, 2017 | Welding Tools
May 02, 2016 | Lincoln Welding Tools
Lincoln electric pro cut 80 want arc
Try replacing it as in remove and than put on again
Nov 25, 2012 | Lincoln Electric - Pro-Cut 80 Amp Plasma...
I'm interested in buying a used Pro Cut 80 that on the inside of welder says 460/ 580 volt ? connection. Can this welder be converted to 240 volts? What if its connected to 240 volts. Will it work? Thanks
I doubt it. You will need the model number to determine for sure. There are two models that are listed for 460/580 with no mention of other voltages. Get the exact model number and you can download a manual at: http://www.mylincolnelectric.com/Catalog/lecooperatorsmanualsearch.aspx
Aug 23, 2010 | Lincoln Electric - Pro-Cut 80 Amp Plasma...
The safety light on the Pro cut 55 will not stop flashing
alot of times the torch can be clogged up and that will make it come on
Apr 20, 2010 | Lincoln Procut 55 208/230/460/1/3/60 50Ft...
Pulses when cutting
if your using a extension cord, either, 1-dont. 2-get a shorter one. 3-get a cord set up for rvs & convert the end for standard(cheaper than buying a welder type extension cord). if your not, the wiring or the breaker may not be matching the draw. make sure something isnt using same breaker as you. (fridg, ac etc).
Feb 10, 2010 | Lincoln Pro Cut 55
Lincoln pro cut 60 status board no lights on but fan has power
Where are you?
Unless you are electrical and modern electronics inclined you may want to find someone with the right training and equipment to service.
Could be a bad power relay.
Thanks,Eric
Sep 23, 2009 | Lincoln Procut 55 208/230/460/1/3/60 50Ft...
Safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Nov 26, 2008 | Lincoln Pro Cut 55
Lincoln Pro Cut 55 Logo
61 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
