Question about Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue
Fault light and hazard lights and horn on continuously
Scooter moves ok but fault light and hazards are on continously
  • Electric Master
  • 1,271 Answers
Hi, Has it got wet ?
If so water collects at the bottom of the switches making a connection, to fix carefully remove the base of the switch and dry, beware here will be a lttle string in there plus bits of plastic... so beware...
Regards
www.gewizrepairs.co.uk
Posted on Nov 20, 2013
Pride Celebrity XL8 - problem with right side indicators
hi Stuart, have you check out the actually switch that you pressed to activate the indicators ?
Regards
Rob
Apr 18, 2016 | Pride Health & Beauty
DMA SCOOTER WONT MOVE ALTHOUGH BATTERY FULLY CHARGED
Are there any fault codes, flashing light. Check your user manual in the trouble shooting guide.
Have you disconnected charger from scooter as it will not move if it is still connected to scooter.
Apr 18, 2015 | Health & Beauty
How to fix scooter when red light flashes 5 times
hi, i need you tell me what controller type is fitted to that scooter before i can be more precise with fault info ,, the controller is a black, or blue or silver box located under the rear cover of the scooter ,, the wires lead to this unit...
Regards
Rob
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
Fault finding
Hi. Maybe a faulty hazard switch. or the alarm is going of, but the alarm horn is faulty. Leave the car unlocked for a while, if the problem persists then replace the hazard light switch.
Jan 08, 2014 | Volkswagen Golf Cars & Trucks
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Constant beeping but scooter will move
okay there sounds like there either water somewhere or condensation ?
place the whole scooter in a warm room next to a radiator, not too close but close enough so it gets the warmth leave it like this to dry out, this has worked for me, water causing a short either under the tiller panel or where the controller is situated.
regards
Dec 15, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Rear lights flicker with hazards
fault in the cluster unit or bad earth clean them down with sand paper to get the **** off then use some wd40 or equivelent and then refit should be ok then
Sep 20, 2012 | Cars & Trucks
Batteries are fully charged with the lights in front and horn working but the lights on rear and scooter will not move. Craftmatic Scooter. Three wheel.
Remove the seat and the plastic cover over the batteries. look at the lights in the cover or at the back of the scooter an see if they are plugged in. It is a common fault of when working on the scooter to forget to plug the lights back in on assembly. Hope thats what it is.
Aug 12, 2010 | Health & Beauty
Dash board of my 2000 crysler voyager keep flashing, and the out side lights do de same thing.
the hazard switch is the problem or it is cause by passive alarm, remove the hazard switch or hazard fuse and observe the function of the lights, if lights stop flashing, change the switch, if continous flashing check the keyless entry reciever or the body control module
Aug 06, 2010 | 2001 Chrysler Town & Country
Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue Logo
70 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
