Question about Canon 730i Laser Printer
Reset toner cartridges
Cant reset toner cartidge, with a new
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 210 Answers
Sign on to Canon's website and download the instructions for changing the toner and resetting the page count.
Posted on Nov 20, 2013
Printer says recplace toner after I have reset a tone cartridge
I have two suggestions for you.
  1. Have Microsoft perform a diagnostic scan and possible fix in three simple clicks of your mouse. CLICK HERE
  2. Download the latest utilities and drivers from Brother by CLICKING HERE
You might also want to review the instructional video by clicking on the link below:
May 22, 2012 | Brother Hl4140cn High Speed Colour Laser...
How to change the toner cartridge on an HP Laserjet 3330 printer?
The panel just above the paper tray is the toner door. Grasp on left and right side, there should be little indents, then pull towards you. Front will open and toner cartidge will move towards you. Grab cartridge and pull it up and out. Reverse procedure to install new cartridge.
Jun 06, 2011 | HP LaserJet 3330MFP All-In-One Printer
NEW DRUM CARTIDGE STARTED USING AFTER I BOUTH IT 1
If it is a rebuilt toner cartridge then you probably will have to replace it. If it is a new oem cartridge (also try it if it is a rebuilt) take it out and ly shake it side to side. Not too hard as you could end up covered in toner. The idea is to break loose and then redistribute the toner powder evenly. Then reinsert and see if that clears your error.
Some printers don't actually measure the level of toner they count pages. So if you print things differantly than what it expects or use rebuilt carts with more toner it thorws that out. Then the only way is to replace the cartridge with a good one to reset the count.
Jul 23, 2010 | Konica Minolta magicolor 2430 DL Laser...
Do you get a new drum with a toner replacement cartidge or is it a separate thing you have to buy
Hello.
The drum and toner cartridge are separate items. Both are replaced by the user.
The toner cartridge holds toner/ink. The drum does the work. You will need to replace the drum for every 4-5 toner cartridges used.
I've seen toner cartridges for your printer at $36 vs $60 for a drum.
Hope this helps.
Jun 13, 2010 | Brother MFC-7440N Laser Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Replace toner problem
To replace the cartridges before they are actually empty you should:
  1. Navigate to the reset menu (using down arrow)
  2. Select this (right arrow)
  3. Navigate till you get to Change Toner x (where x is the colour)
  4. Select this.
  5. Wait for the printer to stop churning.
  6. Open the front door and you should see the correct toner cartridge at the back.
  7. Follow the instructions just inside the door (or on the cartridge box.)
Feb 16, 2009 | Epson Aculaser C1100 Printer
Hl 2040
You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
***Important For Brothers**
Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
Hope that helps you.
Jul 27, 2008 | Brother HL-2040 Laser Printer
HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Dec 20, 2007 | Brother MFC-8460N Laser Printer
Canon 730i Laser Printer Logo
266 people viewed this question
old marine
old marine
