Question about Aerocool PSU |ZERODBA-S620 RT (ZERODBAS620) Power Supply
Problem with new Aerocool Zero Db 620W PSU
I have purchased a new Aerocool 620W PSU above. I have connected all cables correctly but my systems still switches off after a short while. It will thereafter not start up again, unless I removed the main 220V power cable and re-connect. The system then shuts down again in less than a minute. I have a Asus M2-NE SLI mobo, AMD AM2 5600+CPU, Gainward GeForce 8800 GTX Ultra, 2Gb Kingston Ram, 500Gb Seagate HDD. I have build many PC before and never experienced such problems before. I can run the same system on a Gainward 550W PSU and no problems. Please help.
Plug it directly into the wall dont use power bar or check for 120 / 220 volt switch
Posted on Feb 11, 2009
Why am I notI getting a picture?
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.
Mar 29, 2013 | Nintendo Super NES Console
How to express a loss as a gain in dB?
Decibel is what sound is rated in.
The sound level is expressed as a line.
0 in the middle.
Negative values are to the left, Positive values to the right.
Less DB rating to the Left, more DB to the Right.
Anything above the 0 is louder. 1, 2, 3, 4, 5, 6, etc.
Anything below the 0 is not as loud, -1, -2, -3, -4, -5, -6, etc.
It would be correct to state a 6 DB loss as -6DB.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/Decibel
May 17, 2012 | Computers & Internet
When I turn the key on to start my Troy-Bilt RZT 50 zero turn mower, there is nothing. No ignition light, nothing. I have a new battery and I put a new fuse unit but still nothing. Help!
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
May 02, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Hi need a set of temp sensors, the extension cables and the tape for sticking the sensors to the individual components. Where can I purchase these items.The unit is a Aerocool Gatewatch.
Amazon sells it.
http://www.amazon.com/AEROCOOL-GATEWATCH2-BK-TEMP-MONITORING-PANEL/dp/B000MPG7NW/ref=sr_1_12?s=electronics&ie=UTF8&qid=1304319712&sr=1-12
May 02, 2011 | Computers & Internet
My super turns on but i dont get any audio or video but the screen isnt black or nuthin its grey, what should i do?
Other Screen Problems
Feb 21, 2011 | Nintendo Super NES Console
I havent played my super nintendo in a couple years and everytime i try and play it now i just get a blank screen...ive tried rehooking up everything multiple times but the screen is still dark....any...
Blank Screen
Dec 12, 2010 | Nintendo Super NES Console
When I turn on my snes, the screen just goes black.
  • Blank Screen
    1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
    2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
    3. Make sure the system has power. If not, go to the No Power Light instructions.
    4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
    5. There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
  • Other Screen Problems
    1. Make sure you are using only licensed accessories with your system.
      We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
    2. Check all of the system connections to verify that they are firm and correct.
      • For AV connections
        Remove the AV cables and reinsert them with a slight twisting motion
      • For RF connections
        Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
    3. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
      Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
    4. Slide the Power Switch on the Control Deck to the ON position.
    If the above troubleshooting doesn't fix the problem, see below.
Sep 16, 2010 | Nintendo Super NES Console
My super nintendo isn't working. It keeps saying i have know signal, yet it worked fine yesterday. i'm on the right channel and everything is plugged in.
    4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
  • Unlicensed products are not fully compatible with our systems and may not work correctly.
  • Check all of the system connections to verify that they are firm and correct.
  • Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
  • Slide the Power Switch on the Control Deck to the ON position.
  • If the above troubleshooting doesn't fix the problem, see below.
click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Aug 27, 2010 | Nintendo Super NES Console
Motherboard shuts down before booting !
You should clarify this a bit more, but please make sure all of your fans are plugged in and the no jumpers are set to over-clock the processor.Also, double check that everything is fundamentally compatible.
Dec 16, 2008 | Computers & Internet
NO POWER TO MOTHERBOARD
Doublecheck your powerswitch connection on the MoBo header. Also ensure that everything else on the header is seated correctly and tightly.
The case button may also be at fault.
You will then need to start methodical testing.
Sart with the PSU connected to a known good system. if that works you eliminate the PSU (You did turn tis on on the back didn't you! ;-)
If that Doesn't work try a known good PSU on this system.. If that works you for sure know it's the PSU that's dud.
If you have a spare Mobo try swapping the parts into that.
If it's a brand new board then it may be DOA, it does happen, but unlikely. Anthing else after the board actually gets power will mostlikely produce a beep code if nothing else.. Silence and not running is most likely one of the above.
If my solution was helpful please vote for me!
Nov 16, 2007 | Abit NF-M2S Motherboard
Aerocool PSU |ZERODBA-S620 RT (ZERODBAS620) Power Supply Logo
192 people viewed this question
Top Aerocool Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Aerocool Computer and Internet Expert? Answer questions, earn points and help others
