Question about Savin 9060 Copier With Feed, Finisher, Print, Scan - 243k Copies
Need to change email address in scanner - Savin 9060 Copier With Feed, Finisher, Print, Scan - 243k Copies
How do I change my primary email address
hi John.
How do I change my primary email address?
  1. Sign into your Box account.
  2. Click your name in the top right corner.
  3. Click "Account settings" from the pulldown menu.
  4. From the "Account" tab, scroll down to "Login and Email Addresses"
  5. Click "Add more emails"
  6. Add new email address and click "Save"
More items...
How Do I Change My Password Or Email Address? - Box
https://community.box.com/t5/How-to...Account/...I-Change-My...Email-Address/.../8
How do I change my primary email account?You can't change the email address on your account to an email address that's already associated with a Google Account. If you want to make your alternate emailaddress the new primary address, you'll first need to delete your alternate emailaddress from the account.Email addresses associated with your account ... - Google Supporthttps://support.google.com/plus/answer/1045580?hl=enSearch for: How do I change my primary email account?
How do change my primary email address Google Search
Nov 27, 2017 | Computers & Internet
How do I change my screen name
Change your username If you use Gmail with your Google Account, it's not currently possible to change your Gmail username after you've registered unless you want to delete Gmail from your account and use a different, non-Gmail address for your Google Account. You can also create another Google Account with a different Gmail username.
If you don't use Gmail with your Google Account, you can change your account username to another email address at any time. Your username is the full email address you used to create your account.
To change the email address on your account, just follow these steps:
  1. Visit the Google Accounts homepage.
  2. Sign in to your account.
  3. Click Edit in the Email section.
  4. Enter your new email address and your current password.
  5. Click Save email address.
Once you've saved the change, you should receive a verification message at the email address you just entered. To complete the change, you'll need to click the verification link in this message. You should also receive a message at your old email address confirming that we've registered the change to your account. If you don't receive the verification email, check your spam folders or request a new email.
Note:
  • You can't change the email address on your account to an existing Gmail address, but we invite you to add a new Gmail address to your Google Account.
  • You can't change the email address on your account to an email address that's already associated with a Google Account.
  • If you want to make your alternate email address the new primary address, you'll first need to delete your alternate email address from the account.
  • The account username that you choose needs to be an active, valid email address that you can access.
Sep 22, 2014 | Google Gmail
I need to change the email address for my Apple account.It requires me to log in but the old email address is no longer in service.
If Apple uses normal security procedures the fact that your old email account is inactive shouldn't matter to your login. Go ahead and login using the old email address and then change the email address. Apple will then send an email to your old email address to notify you that your email address has changed and that you should notify them if you did not request the change. You won't get that email, of course, but that doesn't matter because you DO want the change.
Sep 15, 2014 | Apple iPhone Cell Phones
Why wont the setup allow me to use my email addy when requested? It says email is invalid.
You can ask question to the seller (what is the registered email address, and later you can change it to your email address).
Feb 28, 2014 | NEAT Desk Desktop Scanner and Digital...
I want to change the "from" address on the scanner to a more generic one, such as copier@.....
From PageScope web connection enter the Admin mode.
Select Network, Email, Email Transmission.
Enter Admin email address.
Enter Device email address.
Select Apply
Jul 08, 2009 | Konica Minolta bizhub C351 All-In-One...
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Scanning for a Konica
Need to go to the user mode, press One touch,enter the address book, then Scan to email, there u can see all the address, select the one which u want to change it.
Jul 18, 2008 | Office Equipment & Supplies
Removing a programed email address from the scanner feature
This has to be a simple process. Need to know the make and model number of your machine. Each machine is different but again it is simple.
May 13, 2008 | Office Equipment & Supplies
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Savin 9060 Copier With Feed, Finisher, Print, Scan - 243k Copies Logo
26 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
