Question about Refrigerators
GE GTS17JBSBB makes chirping/tapping sound
I purchased this refrigerator on Craig's List a couple of days ago. It works well-keeps food cold, but makes a chirping/tapping sound when fan is running. You can hear the sound on the video. Any idea what might be causing it? Is the fan likely to fail in the near future? Thanks
    Novelist:
  • 157 Answers
Thats not a fan noise. to me, sounds like pressure going thru an expansion valve. you better get on an appliance thread website with that one. meantime....loose mounting of condenser pipe or evaporator outlet???
Posted on Nov 19, 2013
4 Suggested Answers
SOURCE: 5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Posted on Mar 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
  • 531 Answers
SOURCE: Refrigerator not keeping food cold
you may have defrost problem
Posted on Apr 06, 2009
Refrigerator no cold
Sounds as if it lost its gas in the move. Check for broken pipework or capillary. It might be repairable.
May 16, 2012 | GE Adora (DSF25KGTBG) Side by Side...
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
My refrigerator is too cold and is freezing my food
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly. Luckily, I found this before rushing out to purchase the control
Hope this helps.....
Jul 30, 2010 | GE Refrigerators
My freezer doesn't keep ice cream frozen more than a couple of hours. Other foods are frozen, but some slightly 'soft' frozen. Up until a couple of weeks ago it would produce ice cubes regularly. Now if I...
YOUR DEFROST TIMER MAY BE BAD OR THE HEATERS ARE BAD. WHAT HAPPENS IS THE EVAPORATOR IS FROZE OVER WITH ICE AND CAN'T TRANSFER THE COLD . UNPLUG THE FRIDGE FOR A FEW HOURS (HAVE RAGS AND MOP READY) AND IT WILL WORK AGAIN TEMPORALLY . THE LESS YOU OPEN THE DOORS THE LONGER IT WILL LAST.. BACK IN THE DAY IT WAS CALLED DEFROSTING THE FRIDGE AND WAS DONE ONCE A MONTH OR SO
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model GSS22JEMDWW. Replaced the compressor six
check the RTX overload on the compressor body its bad and trying to start the compressor
Dec 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
