Question about Husqvarna Model 460 Rancher Chainsaw 60cc with 24 Bar and Chain
Husquvarna brake band adjustment
I took my cover and bar off of my saw while the chainbrake was engaged, i think. Now its nearly impossible for me to get my brake band to slide over my clutch drum. How do I get my brake to be able and slide over my drum ?
  • 1,615 Answers
If you pulled the brake toward you to engage it, simply push it back out to disengage it. (might take more pressure to release it than to engage it)
Posted on Nov 19, 2013
Testimonial: "yes of course but, putting my cover back on properly is impossible because ive taken the cover off while the band was tight and now cant disengage band."
spekgt
  • 60 Answers
SOURCE: chain brake band will not release to replace the clutch cover
Hi there
Sometimes that's not an easy job . I work for a Husqvarna dealer and I have that problem frequently . First try to get the clutch cover on place (do not use the bolts) and push in @ the top part of the clutch cover , then try to move the clutch lever backwards to release the band (better if done with two people) . If that does not work the only way is remove the clutch lever with the 2 bolts on each side and put the lever on the clutch cover (top metal piece that looks like a clover)to release the band (again with 2 people one holds the clutch cover and the other one the lever pulling the lever backwards) .
Hope this help
Hope this help
Posted on Sep 03, 2009
  • 376 Answers
SOURCE: clutch cover wont go back on
Your cover probably won't go back on because the kickback/chain brake is on. Pull the handle on the cover back until you hear a click, the it will go on. As for removing the clutch, you need Poulan tool # 530031112 and an impact witha 3/4 socket. If you're just trying to reset chain break, removing clutch is not necessary, just pull back on handle as I said before.
Posted on May 30, 2009
  • 86 Answers
SOURCE: how to release brake band when cover is removed on model 445 ?
HI. I HAVE USED THEM SAWS FOR 25 YEARS. WELL IT SOUNDS LIKE THE BRAKE IS INGAGED IF NOT YOU WELL HAVE TO LOSEN THE BRAKE OFF UNTIL IT WILL GO ON.WATCH OUT FOR DIRT IN BACK OF BAND. LET ME KNOW.
Posted on Aug 13, 2009
dontbother10
  • 2220 Answers
SOURCE: Brake band will not go over fly wheel
A link to an IPL a 2008 Husqvarna 235E follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2008/I08000/I0801001.pdf
It includes a good illustration of the brake and its' components. It is likely the chain brake is released and will need to be engaged to enlarge the brake band.
Reset Chain Brake
Immobilize the clutch cover (blocks of wood on a flat surface to protect the finish) in a vise or with a large C-clamp to a work surface.
Use pliers or a crescent wrench and rotate it clockwise until it latches open. This will require some force. A slight modification reported in a testimonial to the above method follows;
" Thanks for the help. I took your answer and modified the fix a little. I placed the cover on loosely and then moved the bar handle into the right position in order to engage the spoked wheel, then rotated the handle back until the cover fit right. Thanks, SG "–NameRemoved
All Husqvarna OMs and IPLs can be found here:
HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 21, 2010
  • 130 Answers
SOURCE: have tried everything but cover will not go back
The problem you are experiencing is very common. Many people remove the side cover with the chain brake applied or either the brake becomes engaged after the cover has been removed. You will need to reset the brake before you can install it. This is a little tricky but can be accomplished. I find that it is done fairly easy by carefully clamping the side cover in a vise, and using a good strong pair of needle nose, span the "rotator" (star shaped wheel) on the brake and with another pair of pliers, grab the needle nose pliers and "twist" the brake into the disengaged position. Hope this is explained well enough to get the job done.
Posted on Mar 04, 2011
Why does the chain brake not work?
1. What is the make and model of the saw?
2. Does it make any sound when you push the chainbrake handle towards the front (the bar and chain direction)?
3. The idea, and the way it works is that as the bar and chain get jerked upwards towards your face, your left wrist catches the chainbrake handle and pushes it forward thus engaging the chainbrake.
May 10, 2014 | Stihl Garden
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
Change the chain instructions
General instructions are, if the machine has a chainbrake make sure this is off, loosen the side cover nut/nuts, wind the bar adjuster screw back to slacken the chain, remove the side cover, push the bar back to the sprocket, the chain should now be lose enough to lift it off the tip of the bar and un loop off the sprocket, now loop the new chain over the sprocket and around the tip of the bar, make sure the cutters on the top of the bar are facing away from the saw ( a pushing chain )now re fit the side/chainbrake cover, if the bar adjuster pawl is in the brake/side cover, make sure this aligns with the adjuster hole in the bar, re fit the bar nut/nuts finger tight, wind the adjuster screw in so as the chain sits snuggly all around the bar, with a gloved hand pull the chain around the bar manualy, it should pull smoothly, lift the tip of the bar up and fully tighten the nut/nuts, run the saw, there will be an amount of initial stretch, slacken the bar nut/nuts and re tention.
Aug 24, 2011 | Poulan Pro Chain Saw 46cc 20"
I Have 235 husqvarna chain saw I took the clutch cover off now i can get it back on. ring will not go over the clutch gear.
The chainbrake has activated, you need to load the brake, the best way is to clamp the cover in a vice, be carfull not to damage it, remove the hand guard from the saw, now use this as a tool to fit into the brake mechanism and load the brake, it will take a fair amount of force as there is a large compression spring under the cover.
Aug 08, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
After changing the chain, I can't get the cover back on the saw in a proper manner. It seems as the brake will not open wide enough to go over the clutch drive plate. What am I doing wrong?
Unfortunatly you have removed the chainbrake side cover with the brake on, the band is now smaller than the drum and will not go on, you now need to load the brake, this is not so easy as the hand guard is still on the machine, the best way to do this is to clamp two 8mm bolts in a vice, space them the same distance as the holes in the brake cover, now put the brake band side up onto the bolts and use the bar nuts fron the saw to secure, this will now hold the securley, now you can eithet take the hand guard off the machine, and engage it into the three legged mechanism and pull back to load the brake, or find a suitable tool to engage into the mechanism to load the brake, a word of warning it has a very strong spring inside so will take a faie amount of pull to compress the sprong and so load the brake, DO NOT remove the cover over the spring, this can and will posibly fly out and cause injury.
Feb 20, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I'm looking for a way to adjust the E-Brake on my Homelite 18" Chain Saw. Its model UT10830. The Saw runs great it just seems that the Brake keeps it from cutting properly by not allowing the chain to turn...
remove the nuts that hold the bar & the screws that hold the cover on.w/ brake off,remove cover.inside cover you will find 'band' brake that surrounds sprocket assembly.if adjustment is provided,it will be at one end of the band.it's more likely to be an accumulation of sawdust interfering w/brake.also clean sawdust from chain oiler holes in bar,and around sprocket while you've got it apart.slacken chain adjuster screw to aid re-assembly,re-adjust chain
Sep 26, 2009 | Garden
Hi, I took off the clutch cover for my Husqvarna 136 saw and I can't get it to go back on. Any suggestions?
you need to disangage you chain brake band as it is engaged and wont go over the the clutch hub sprocket
Aug 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I can't get the clutch cover back on my Husqvarna 235 e because the chain break is engaged. Spring is too tight to disengage it.
The chain brake is engaged when the brake handle is moved forward.....to ensure it is actually the chain brake...with the clutch cover off and in your hand, pull the chain brake back...if it will not move, attempt to move it forward to see if it was not engaged...if it moves forward, it is now engaged...pull back to disengage it...a lot of times the problem is not the brake, but rather the bar adjuster....if the brake is not the problem,...loosen the bar adjuster and reassemble the unit...once assembled, then adjust the bar as per the user manual.
let me know what you find.
clarkco
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
18" husqvarna chainsaw
It sounds like your chainbrake was on when you took off side cover .To get brake off place cover against saw with bar off so cover fits into brake lever and pull back on lever
Oct 14, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna chain brake
You'll have to release the brake with the cover off the saw. You just need to find a way to brace it well enough.
If you really can't do this, then it suggests your chainbrake is faulty, of ath the very least not adjusted right.
Sep 18, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Model 460 Rancher Chainsaw 60cc with 24 Bar and Chain Logo
65 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
