Question about Radio Communications
Sharper image freedom Bluetooth model number ESI-P400 how to put in pairing mode.
    Problem Solver:
  • 16 Answers
To pair your device with The Sharper Image Freedom:
  1. Make sure your device has Bluetooth capability.
  2. Slide the POWER switch to turn on the Freedom, indicator will begin to flash.
  3. Follow the instructions of your device to pair the unit.
  4. Pair your device with the unit by selecting FREEDOM from your Bluetooth listings on your device or selecting YES. If prompted, enter "0000" as the passcode.
  5. Press play on your device and use controls on the unit to adjust desired volume.
Note: Once you have successfully paired your device, you typically will not need to repeat the above steps. Please ensure the Line-In cable is unplugged, the unit source is set to Bluetooth and your device has Bluetooth enabled.
Note: The effective Bluetooth range of the Freedom is approximately 30 feet.
Posted on Nov 19, 2013
5 Suggested Answers
  • 12 Answers
SOURCE: need plantronics 320 pairing code
it's either OOOO or 0000.
Posted on Feb 18, 2009
  • 86 Answers
SOURCE: how to put motorola bluetooth in pairing mode?
Hi there - follow the step-by-step instructions here:
http://direct.motorola.com/eng/bluetoothselect.asp?country=GBR&am
Just pick your model and it will guide you through it;
Posted on Aug 29, 2009
jyackle5
  • 8197 Answers
SOURCE: how do I put this bluetooth (ant Z9i)into pairing
Pairing Procedure (This is an example only and may differ from your phone, but the process will be the same.)
1. First turn the phone OFF and then back ON again to refresh its memory.
2. Bring the mobile phone to about 30cm from the Z9i Dual Microphone.
3. Find the Bluetooth menu in your mobile phone. Turn Bluetooth ON. (Check your mobile phone user guide if necessary)
4. With the Z9i OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start fl ashing. The
Z9i is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
5. Perform a Bluetooth device discovery on your mobile phone to add a new device. (It takes a few seconds to search for
and fi nd other Bluetooth devices around you).
6. When Bluetooth devices are found, the phone will display “BlueAnt Z9i”. Scroll to it and press OK to confi rm that you
want to Pair with it.
7. Enter Passkey “0000” when your phone prompts you. The phone and Z9i will now Pair.
8. An additional security setting in your phone may be needed to allow the headset and phone to connect automatically
without confi rmation each time you connect your Z9i. Generally in the options for the BlueAnt Z9i, it will be referred to as
“set as authorized”, “add to trusted devices”, ‘’allow connection’’ or similar.
9. If required for fi rst time connection, select the BlueAnt Z9i to connect with your phone. OR, Click the MFB on the Z9i,
to connect with the phone.
You can get the manual on link below. page 9 tells you how to pair.
http://myblueant.com/downloads/manuals/Z9i_manual.pdf
good luck and please rate 4 thumbs for the free answer
Posted on Mar 29, 2010
faceofftech
  • 185 Answers
SOURCE: need to put bluetooth in pairing mode and lost
how to connect a bluetooth to a cellphone
1. go to the menu on you cellphone and find connections-bluetooth
2. click options
3 be ready to click search for device (don't click it yet)
4. press the on button and your earpiece and hold till you get a solid bluelight.
5. when you get the solid blue light on earpiece click search for device
6. when it finds your device select it and click on it
7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000
8. it will ask you to confirm click connect
you should be able to connect.
if it works for you don't forget to rate me
thx
Posted on May 01, 2010
N manual to cover and remote
PDF]Owner's Manual Freedom Basic Remote Xantrex Freedom ...
www.xantrex.com/.../Freedom%20Basic%20Remote/Freedom%20Remot...
Freedom Inverter/Charger Remote Control Panel is not intended for use in .... n. Freedom charging. INVERT. O ff Invert function Off. Power Up Indications and Default V ... Xantrex covers both parts and labor necessary to repair the product, and ...
Product Information: Roamio Remote Control - TiVo
https://support.tivo.com/articles/Product.../Roamio-Remote-Control
TiVoAllow Pairing mode: This pairing mode is for manually adding a new remote control or transferring a remote control from one DVR to another. When you put the ...
[PDF]REMOTE CONTROL RC-N - Bernafon
Jan 01, 2016 | Televison & Video
I've successfully paired the peaker but no sound is coming out
might I ask how do you know you were successfull if no sound is forth coming .
Mar 31, 2015 | THE SHARPER IMAGE ESI-P400 Freedom Premium...
How do i set the time?
Have you tried Sharper Image ? on customerservice@sharperimageonline.com
Surely they MUST be able to help with an instruction manual if you ask nice.
Aug 10, 2014 | Sharper Image Relaxx Dual Bedside Audio...
My speaker does not connect to my ipad
The speaker has to be paired with your iPad before it will work. Check your documentation on how to put your speaker in "discoverable" mode long enough for the iPad to find it. If you have previously paired your speaker and it at one time did function is your iPad, make sure that Bluetooth is turned on on the iPad. Also, check the batteries on the speaker if it has previously functioned with your iPad...
Jun 21, 2014 | iLive Bluetooth Speaker System
Sharper image manuals
I need the manual for the ESI-B622
Jan 03, 2014 | Sharper Image Relaxx Dual Bedside Audio...
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
Sharper image freedom Bluetooth speaker model ESI-P400 discovery mode button sequence
Nov 19, 2013 | Radio Communications
Set time on sharper image esib622
Sharper Image ESI-B622 Relaxx Dual Bedside Audio Dock
1. Turn off power
2. Press and hold "Play/ Pause" button until time flashes on hour.
3. Use the << / >> buttons to change the time NOT the "+/-" buttons
4. Press and hold "Play/ Pause" button until time flashes on minutes.
5. Use the << / >> buttons to change the time NOT the "+/-" buttons
6. Press and hold "Play/ Pause" button until time flashes on days.
7. Use the "<< / >>" buttons to change the time NOT the "+/-" buttons
TRUST THIS WILL WORK BECAUSE I HAVE ONE AND THE INFORMATION THAT EVERYONE HAS PUT ON HERE WAS BS.
Jun 13, 2012 | Audio Players & Recorders
I need to know how to sync my komodo freedom bluetooth headset to my ps3.
Hi there Sk8 demon. I should be able to help you with this problem. The first thing you must do is to put your bluetooth headset into what is known as pairing mode which prepares your bluetooth headset for syncing with your PS3. With your particular model you'll need to hold down the talk button on your headset until the light turns solid. Next in your PS3's XMB menu look for accessory settings then select Register Bluetooth Device followed by Register Headset. Next it will scan for your headset until it (pairs). If you are asked for a code it is almost always 0000. You should be ready to go. Hope I was helpful.
Apr 22, 2011 | Video Game Consoles & Games
Nexxus bluetooth car kit
To pair you must first turn bluethooth feature ON on Sony phone. This usually has an indication on lcd display when it turned ON (it looks like a headphone sign) the you must turn visibility of your phone ON making it ready to be paired. Following instruction that came with bluetooth kit put bluetooth in pairing mode when its in paring mode led lights will rapidly fash. At this point you phone should pick up bluetooth if it doesn't then do a search for bluetooth devices with your phone and it will find the bluetooth (make sure its in pairing mode) It will display the bluetooth type and model number. It also may ask for security code if it does it 0000 set by default. Then pairing should be complete just save and you should be good to go. Good luck and thanks for using fix ya
Jan 28, 2009 | Cell Phones
Radio Communications Logo
512 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
