Question about Seagate Computers & Internet
Had adjustment on model no. std18000n - Seagate Computers & Internet
    Scholar:
  • 74 Answers
Hi Jeff
The head and guides should not need adjusting on this drive. This was a common issue on HP drives but no adjustment should be needed on this model.
If you are having R/W issues then try a cleaning tape and then a brand new data tape.
If that doesn't work then i think replacement is the best option.
These guys have stock if you need one.
http://tape-drive-repair.com
You can also look for the STD28000N as the only difference is 3.5 vs 5.25 and you can easily convert between the two.
Posted on Dec 03, 2013
I have progressive shocks on my 2012 flhr how do I adjust them to keep the bike from bottoming out. There not air shocks
Motorcycle Suspension Adjustments Progressive Shock Adjustments
Here is one YouTube video on adjusting MC shocks. If this isn't the right model, check YouTube for your model. There are more videos on adjusting shocks.
May 05, 2015 | Motorcycles
I am looking for the screw and nut aka chain tensionor for a Mac Cat 16av Model CS 38 EM. Thanks
The adjustment screw is in the outer cover near the bar . Just loosen the 2 outer nuts and then adjust chain with the adjustment screw on the front of the outer cover. Some models have adjustment in the bar itself.
Dec 31, 2014 | Garden
Adjust the chim on a model ffw 5000qw drigidaire washer
Hey friend, thank you for your inquiry!
I see that you would like to adjust the chime on your Frigidaire washer. I researched the model number you provided, FFW5000QW but was unable to locate any information on it. Could you verify the model number for me please? You can locate your serial tag (which lists your model number) on the door frame of your washer with that information I can double-check to verify if the chime can be adjusted. -Matt
Sep 29, 2014 | Frigidaire Washing Machines
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
Can build up of dust cause the convergence not to adjust properly
Dust will not be a issue with convergence.
Not knowing brand and model and if adjustments were "saved" you could also have a problem in the convergence circuit--chips or other parts.
Brand and model are needed first.
Dec 11, 2012 | Televison & Video
Ac Belt diagram for a 1997 Acura intrega
ADJUSTMENT
Inspect the drive belt(s) every 30,000 miles or 24 months. Determine the belt tension at a point halfway between the pulleys by pressing on the belt with moderate thumb pressure. If the deflection is found to be too much or too little, perform the tension adjustments.
On some Acura models it will be necessary to work from beneath the vehicle when servicing the accessory drive belts.
Before adjusting, inspect the belt to see that it is not cracked or worn. Be sure that its surfaces are free of grease and oil. If contamination is present, belt replacement is recommended.
  1. Push down on the belt halfway between pulleys with a force of about 20 lbs. The belt should deflect: 0.16-0.41 in. (4-11mm)-on Integra and 0.22-0.45 in. (5.5-11.5mm) on all other models.
  2. Adjust the belt tension by loosening the adjusting bolts.
  3. Next loosen any mounting bolts and/or nuts that may hinder adjustment.
3.0CL models have automatic tensioners therefore no belt adjustment is required.
  1. To adjust the alternator belt tension on Integra, loosen the adjustment lock bolt and move the alternator with a prybar positioned against the front of the alternator housing.
WARNING Do not apply pressure to any other part of the alternator or damage may occur.
  1. To adjust the tension on all other accessory drive belts (all Acura models except 3.0CL), loosen the adjustment lock bolt and turn the adjusting bolt (if applicable) as required.
Do not over tighten any of the belts. Damage to the pulley's bearings may result.
  1. After obtaining the proper tension, tighten the adjustment lock bolt.
  2. Tighten all other bolts and/or nuts that were loosened in the adjustment process.
See Figures 6 through 13
Fig. Fig. 6: Location of adjusting mechanism for the A/C belt on the Integra's 1.8L engine
Fig. Fig. 7: Alternator belt adjustment-Integra
Fig. Fig. 8: Power steering belt adjustment-Integra
Fig. Fig. 9: A/C compressor belt adjustment-Integra
Fig. Fig. 10: Alternator belt adjustment-3.2L engine
Fig. Fig. 11: Power steering belt adjustment-3.2L engine
Fig. Fig. 12: A/C compressor belt adjustment-3.2L engine
Fig. Fig. 13: Belt routing and alternator belt adjustment-2.5L engine
REMOVAL & INSTALLATION
Many Acura models are equipped with a theft deterrent audio system. Make sure you have the necessary code before disconnecting the battery.
  1. Disconnect the negative battery cable.
  2. Loosen the driven accessory's pivot and mounting bolts.
If removing the alternator belt on a 3.0CL, pull back on the belt tensioner with a commercially available tool.
  1. Remove the belt.
  2. Install the belt by moving the accessory toward or away from the engine until the tension is correct. You can use a wooden hammer handle, or broomstick, as a lever, but do not use anything metallic, such as a prybar. Certain models may utilize an adjusting bolt to do this work for you. Simply loosen the mounting bolt and turn the adjuster.
On 3.0CL pull back on the tensioner to install the belt, the tension is automatically set.
  1. Tighten the bolts and recheck the tension. If new belts have been installed, run the engine for a few minutes, then recheck and readjust as necessary
May 05, 2012 | Cars & Trucks
Need to find out how to adjust vavles
If your engine is an overhead valve Briggs. You need to:
Remove valve cover
Locate rocker arms. Upper is exhaust, Lower is intake.
Loosen the lock screw in the center of the adjusting nut.
With engine at TDC and both valves closed adjust both valves by turning the adjusting nut to obtain proper clearance. Once set, tighten the center lock screw.
Valve adjustment specifications vary from model to model. Would need more engine information to get you that or it can be found online.
Reinstall valve cover, make sure gasket did not get damaged.
Adjust valves on a "cold" engine.
Feb 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The water is too cold in our newton water cooler. Is there an adjustment to make it warmer?
Yes there is an adjustment. Your water cooler should have a temperature control The enclosed adjustable thermostat is factory presetand should require no adjustment other than for altitude requirements. The temperature control should also be easily accessible.
Without specific model information difficult to identify where the temperature control may be located on your unit.
You might vist their website to identify your model. A search by model number may find more useful information on accessing and adjusting the temperature control.
Trust this is helpful.
Dec 17, 2010 | Computers & Internet
Kennet Cole Mens Watch Model A126-08 KC1494 How to adjust time
I have a Kennet Cole Mens Watch Model A126-05 KC1296 and I'd liked to know
How to adjust time
Jan 16, 2010 | Kenneth Cole Watches
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
Computers & Internet Logo
52 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
