Question about Buffalo Technology MiniStation Computers & Internet
My external hard drive that I bought overseas isn't being recognized by my computer.
The light comes on and the computer makes the noise that a device is attached; however, it doesn't show up in my computer. I cannot download an updated driver from the manufacturer because it says the serial number on the back is invalid. Some of the writing is in Korean, so I'm not exactly sure what it says. It has all of my travel pictures on it, so I need to know how to access it, or how to back up the data so I can format it for my computer.
  • 89 Answers
Assuming the drive is not defective, try connecting it to a linux computer. Could be a flie system incompatibility issue.
Posted on Nov 20, 2013
4 Suggested Answers
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Posted on Jul 24, 2008
  • 7 Answers
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
rustysheriff
  • 344 Answers
SOURCE: Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective.
Posted on Jun 02, 2009
Laptop no longer recognizes my iomega external hard drive
How old is your OS maybe driver needs for that device for that device is corrupt try to localize and reinstall driver for external HDD
Apr 17, 2012 | Iomega Computers & Internet
My Western Design 120G external hard drive is my back up source. I've had it for a long time and i keep it in its original box when not in use. I just tried to do another back up and when i plug it in,...
the red light probably suggests a problem, habe you recently had any other type of removable or network storage attached, mapped network drives or anyhting like that?
you say the computer recognises it was plugged in, i presume from the noise the computer makes? i would first be checking the device manager to see if there are no problems (right click my computer - properties - hardware tab - device manager), look for any yellow exclamation marks or question marks..
secondly i would make sure it hasnt tried to assign the same drive letter to the external as something else plugged into the machine or something silly like that, check the disk manager..
(right click my computer - manage - on the left click disk management)
look in the list at the bottom for the drive, even if it isnt accessible in my computer, if the computer recognises it as any type of disk at all, it will show it here.. if it does, look at the drive letter, and if it has the same as something else, simply change it (right click the external - change drive letter and paths) remove the current letter - follow the same process again and give a new one that is unused
if there is nothing under device manager, and no external in disk management when it is plugged in, then i dare say its probably had its day..
hope this helps
Sep 03, 2010 | Western Digital 120 GB USB 2.0 Hard Drive
I/O Magic 320GB external hard drive making clicking noise
it happens when the hard is gone bad or can`t be recognised.you can try uninstalling the drive from device manager.you can check the hard drive case or can try the hard drive on some other computer.
Jul 08, 2009 | Computers & Internet
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Light turns on but My Computer does not recognize the drive
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Nov 18, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
91 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
