Question about Harman Kardon AVR 310 Receiver
The source light does not illuminate and there is no sound
My inrared stopped working on my LW2711 camera. Can it be fixed?
Hello Lorex you mean to say Infrared Illuminator?If yes then you can watch this video might be it will help you to repair your Illuminator device.https://www.youtube.com/watch?v=SI7_zXGJCgY
Jul 26, 2014 | Lorex Home Security
Tip
Source
the intensity of illumination of light source varies inversely as the square of the distance between the source and the piont at which the measurement is taken. if =20 lumens when d=5 meters, find i when d=2 meters
on Mar 02, 2010 | Eagle Summit Cars & Trucks
What electrolytic capacitors need changing on a LG W2242S
Start with any which are showing any signs of doming or bulging and any near a source of heat. Use height temp replacements.
Jul 18, 2014 | LG Computers & Internet
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
Buzzer sounding sporadically while driving...no warning lights illuminated. what could be the possible source of this issue? The problem started after air conditioning condenser was replaced.
On most vehicles you will hear a buzzer when the car is in gear and a door is opened. Could have a wire (hot or ground) gotten disconnected in the condenser replacement?
Jun 24, 2011 | Chevrolet Blazer Cars & Trucks
Only 1/2 of my mitsubishi 62 inch dlp tv screen illuminates.
Sounds like one of the light sources has failed or half of the projection source has failed(first is more likely)
If your TV is still on warranty you may want to call them to come pick it up. I doubt you'd want to move this yourself since it weighs over 100lbs
Aug 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
What to connect ignition and illumination to in a boat install
Hello tblau7716,
The ignition wire (usually red) should be connected to a switched 12V source. If your boat does not have an ignition switch, simply wire it to the 12V source through a toggle switch. Just turn the toggle on when you want to use the audio system. As for the illumination wire, cap it off to keep it from shorting out on anything else. It's normally connected into the dash light dimmer circuit so the system display will dim when you turn the lights on. It's not needed for any other purpose and it won't hurt anything to keep it disconnected.
Hope this helps.
May 05, 2009 | Car Audio & Video
My TV set do not come on. It only binks a blue and a red light and I hear a fan noise that comes on and off
It sounds like the lamp is blown. You need the lamp to give illumination. If you have the technical experience to fix it you will need to source a replacement locally.
Jan 18, 2009 | Televison & Video
Harman Kardon AVR 310 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
