Question about Miller Spectrum 375 X Treme Plasma Cutter 907339
The cup light comes on but blows air and wont arc
My horn wont stop blowing unless the battery is disconnected
There is a good chance the horn relay's contacts have arced together. Did the horn go nonstop after you used it or did it just start blowing out of thin air? If it happened spontaneously, you probably have a short in the horn circuit before the horn relay.
Jun 26, 2011 | GPS
(B30 mini) no water comes out... we have had it for 3 weeks, I have cleaned the needle... and the funnel. Everything goes as normal, the water heats until it is time for the coffee to come out- then the...
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
Jan 11, 2011 | Keurig B60 Coffee Maker
Need instructions on how much water and how much rice for rice cooker
answer from page 6 of the instructions: http://www.aroma-housewares.com/manuals/ARC-914S_InstructionManual.pdf
UNCOOKED RICE
WATER WITH MEASURING CUP
INNER POT WATER LINE
1 Cups
1-1/2 Cups
Line 1
2 Cups
2-1/2 Cups
Line 2
3 Cups
3-1/2 Cups
Line 3
4 Cups 4-1/2
Cups
Line 4
Sep 12, 2010 | Aroma ARC-914S 8-Cup Rice Cooker
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
No arc. Power and Air OK
if the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
May 13, 2009 | Welding Tools
Cornerstone p1600 flickering / arcing
Chuck,
Yes, dust accumulation will cause this and sometimes humidity.
You probably wont find much about arcing in a product manual.
The High voltage comes off the horizontal drive circuit through a transformer. Flickering says the CRT and the circuit is working. You just are getting a high voltage arc to a ground source before the CRT.
If you open this up, use extreme caution. You will be dealing with high voltage. Consider it a STUN-GUN! If you have a heart condition JUST SAY NO. Go shop for a new flat panel and recycle your old friend. I understand. I too am a hard sell if it can be fixed.
IF NOT THEN...
Place it in a dark room, turn it on and observe where the arcs are coming from and going to. TURN IT OFF. UNPLUG IT FROM POWER! (Most CRTs have an instant-on when plugged in)
Locate the suction-cup looking connector and wire on the back of the CRT. Use a vacuum first to remove as much dust and lint as possible.
The auto store sells ELECTRONIC CLEANER as well as SILICONE GREASE (for sparkplug wires). Do NOT use any thing that will leave a residue.
Clean the entire wire, connector and socket and any other area that you may have found in the dark test.
Use the silicone sparingly coat the contact area of the socket and wire.
IF there are other arc issues somewhere you may use silicone grease or silicone rubber to repair.
Good Hunting!
Jun 06, 2017 | Cornerstone Professional P1600 Monitor
1999 cadillac deville air wont work
There's a blower motor (fan) under the hood and up against the firewall near the center of the car that takes some work to remove. It has gone out in the last 2 of my 4 Cadillacs. Turns out if you're not real careful with the positioning of the spark plug wires they will brush up against it, and if one of them gets cracked or brittle it will "arc" and short out the blower motor. The a/c compressor should still come on (you'll hear a click when it engages) but you won't get any air blowing into the cabin, hot or cold.
The part was like $200 stock (year 2000 prices) and it took about an hour to remove it. My Caddy at that time had this damn strut bar going across the engine bay which we eventually removed to get to the blower motor.
Dec 18, 2008 | 1999 Cadillac DeVille
Lost rice measuring cup
http://www.retrevo.com/support/Aroma-ARC-838TC-manual/id/21195bh127/t/2/
You can download the manual. The standard rice measuring cup is 180ml (one cup in the US is approximately 240ml).
Nov 26, 2008 | Aroma ARC-838TC 20-Cup Rice Cooker
Heater not blowing
Plug out the unit and check loose terminal connection inside the control, check also partially burned wire.
Feb 06, 2008 | Intertherm P3RA-048K Air Conditioner
Miller Spectrum 375 X Treme Plasma Cutter 907339 Logo
61 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
