Where is the filter hotpoint HV6F160
I cannot find the filter for my washing machine
IFIXALL
  • 868 Answers
SOURCE: Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
Posted on May 26, 2008
  • 1462 Answers
SOURCE: filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Posted on Jun 29, 2008
  • 15 Answers
SOURCE: Where are the filters in Hotpoint Aquarius WF340 washing machine
if you dont have one in the front under the lid your model comes with a slip on filter that goes on top of the aggitator you schouldnt run it without it because ge pumps have a tendacy to freeze up with the lint from your clothes especcially levis hope this helps
Posted on Dec 18, 2008
amgm
  • 32 Answers
SOURCE: can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Posted on Feb 19, 2009
  • 662 Answers
SOURCE: hotpoint wma11 where is the filter?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
Where is the filter on the on the Hotpoint Aquarius washing machine
The filter is inside the machine accessed from the back, see /www.youtube.com/watch?v=R__JTUX9nk4 . Hope this helps
Jun 19, 2016 | Hotpoint Washing Machines
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
Where is the filter on a hotpoint aquarius 1000 washing machine
The filter is underneath the machine,tilt it backwards look underneath and
you will see a rubber pipe with a plastic inner with a clip on the end.
Undo the clip and slide the filter out.
Apr 06, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Can you remove hotpoint bwm 12 washing machine filter
Cheers
Feb 19, 2009 | Washing Machines
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
How do i check the filter on a hotpoint washing machine
no filter but pump may be plugged remove front panel pump om right side ..to remove panel putty knife press hidden clips under front edge and pull panel forward
May 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
