Question about Kenmore Washing Machines
Kenmore 40441900 interior light
Interior light won't go off, won't power on after a few minutes of being plugged in
  • 13 Answers
SOURCE: interior lights, power mirrors and cargo lamp doesn't work
check your fuse.
Posted on May 24, 2009
  • 10 Answers
SOURCE: Drivers door power window control stopped
Since it is only happening on the drivers side door to multiple switches and lights on that door only, I think the problem is the wiring harness as it enters the drivers door by the door hinges.
Posted on May 30, 2009
  • 811 Answers
SOURCE: fuse blowing on interior light/ remote
check for shorts
Posted on Sep 20, 2009
pops296
  • 174 Answers
SOURCE: Interior trailer lights dont work
On some of the vehicles, the ignition switch must be on to power the 12 volt lights. Try that first. I assume that you are using a 7 pin connector, otherwise the running lights can feed power to the interior lights. You can bypass this by running an inline fused wire from the battery to the wiring, but you must disconnect the switched wiring and secure it. You don't want feedback into the wiring harness. Also try http://www.etrailer.com/faq-wiring.aspx. They have a great website with lots of info.
Posted on Oct 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: No power to Kenmore HE2 Front Load Washer
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Interior lights won t turn on
It can be one of two problems. One: pending on what kind of car you have. ..there is a switch near the steering column that turns left or right...adjusting your dash lights and or turning on/you interior lights.#2...check the interior fuse bus panel/box
May 22, 2014 | 2005 Jaguar S-Type
Washer just finished a load worked fine, went to start new load and power button doesn't work but light for the door is on. Kenmore front loader mdl 40441900
Make sure clothing is not keeping the door from closing right, and the machine has had enough time to reset between loads.
Nov 26, 2013 | Kenmore Washing Machines
Whirlpool interior light won't shut off
That is a really good question....what category did you post it under?
May 28, 2012 | Cars & Trucks
Peugeot boxer van 2007 changed interior light bulb blew fuse, renewed fuse, lights worked, but emissions lights on dash board came on and won't go out. Help
Try reading the OBDII with a code reader and see what it is then erase codes and see if it stays off ,could be more than one circuit on this fuse so the fuse blowing has thrown the light on for whatever reason ,Also try disconnecting the battery just out of interest for a few minutes and reconnect it might go out if your lucky
Feb 27, 2012 | Cars & Trucks
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
Nov 09, 2010 | LG WM2501H Front Load Stacked Washer/...
Power windows, sunroof, interior lights not working. Fuse?
I just saw your posting. Yes, It could be a fuse, a 10amp interior light fuse BUT... I had to replace the Central Locking Control module which toasted first... I had the 3 open door, no working lights/windows situation too...
The problem seems to be in the main cabin light which has the 3 way rocker switch. Turn this off (depress the side on the driver side of the car (US)). Check the 10 amp fuse for the interior light. If it is burnt, you are OK if its not, you need to replace the Central Locking module. ~$200 US
I still have not replaced the cabin light module where I think a short is. If I replace the fuse in question, and turn the cabin light on, it "pulses" for a few minutes and then cooks the fuse.
May 09, 2009 | 2004 Audi A6
Interior light and diagnostic plug doesn't work
The data link gets it's power from fuse no. 3(20 amp) in the interior fuse panel,which also is the power for cig. lighter. This fuse gets it's power from fuse no. 103 in the battery junction box (50 amp).
For the interior lights the door adjar switches in the door send a signal to the GEM module.It then grounds the coil side of the interior lamp relay. The switch on the dash that you turn on manually also grounds the coil side of the interior lamp relay so that would mean that everyrhing after the GEM is ok.Are the lights not turning on from any door including the deck lid? If not then problem would have to be in the GEM module.
Feb 26, 2009 | 2000 Ford Expedition
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
