Question about Roper Kitchen Ranges
Gas range makes noise
I have a gas range that makes loud whooshing sound before it will light. I have replaced the igniter so that is brand new. I turn on the oven and wait sometimes 20 mins or more before it finally lights and that's when there is a loud whoosh sound but never the smell of gas leaking. I have been afraid to use it for almost a year now so I don't know if its a good idea to try and turn it on. Any advice would be great!
4 Suggested Answers
  • 93 Answers
SOURCE: gas leaks into oven when i turn on the broiler
You have what we called delay ignition. may be the broiler ignitor too far away from broiler, partially clogged broiler orifice or bad ignitor, I"ll check the Amperage on the ignitor, it should draw above 3 AMPs, if not, then I'll change the ignitor first then check the orifice. Have fun.
Posted on Mar 02, 2010
heatman101
  • 43501 Answers
SOURCE: upper oven makes loud whooshing noise sometimes ,
The gas is not the problem... the ignitor is...
The gas is building up in there before it ignites because the ignitor is not working properly...
Replace the igniotr and the problem will go away..
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 11, 2010
  • 149 Answers
SOURCE: Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Posted on Mar 27, 2010
Viking VGIC oven burners ignite but cycle off repeatedly temperature rarely gets to 300 after 30 minutes. If igniters ignite is problem elsewhere - like bad bi-metal valve? Range and broiler work OK,
There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
Nov 02, 2016 | Viking Kitchen Ranges
I was using my oven when all of a sudden there was a loud whoosh sound. Since I use propane I immediately turned off the oven.
Hi, it sounds like you may have a gas leak some where else on your oven probably from the supply pipe . It looks like it is building up then its been ignited so you get a whoosh. Best get it checked out.
Jan 30, 2016 | Kitchen Ranges
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Jun 26, 2014 | Kenmore Kitchen Ranges
Brand new Whirlpool WFG371LVS Range has a burner that is leaking and when it comes on, it's huge. If you turn on the other burners when it's on, the huge flame gets smaller with every burner you...
It seems to me that espically if brand new and this happened th efirst time you used it,the gas pressure regulator was set for propane at the factory instead of natural gas
as far as for the leak that valve needs to be replaced in warranty but the decreasing flame size is due to incorrect regulator setting
Aug 03, 2011 | Whirlpool WFG371LVS Stainless Steel Gas...
My oven makes a noise before it lights. A "whoosh"
That is common with gas since the gas fills the entire element before there is enough gas for the pilot to ignite. You have the same thing with outdoor gas grills.
Feb 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Upper oven makes loud whooshing noise sometimes , like the gas ( propane )is blasting full tilt model mgr6775 ,mgr6875
Heatman101
Mar 11, 2010 | Maytag MGR6775 Stainless Steel Kitchen...
Everytime i use my frigidaire gas stove burner, it will make a loud humming noise. when i turn on a 2nd burner the humming sound will go away..is this normal for this brand?
SOUNDS LIKE YOU HAVE A REGULATOR PROBLEM. IT WONT HURT ANYTHING ITS JUST ANNOYING. OR YOU CAN REPLACE THE REGULATOR
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 07, 2010 | Frigidaire FGF366E Gas Kitchen Range
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Kitchen Ranges Logo
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Craig Butler
Craig Butler
Jim Thurston
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
