Question about Saddleman Rear Row Neoprene Seat Covers Quantum 85-88 19924-40
Why quantum diesel hard starting in the morning
  • 1,615 Answers
A partial blockage of the fuel system. The most
likely place for a blockage is at the main fuel filter, situated on the fuel line between the fuel
tank and the engine. The fuel filter is a bowl containing a disposable cartridge made of
corrugated paper designed to remove dirt particles greater than 10 micron in diameter.
Some filters will also remove water which is collected in a trap and must be drained at
regular intervals.
The quickest way to resolve the problem is to get a sample of the fuel from the fuel tank
before the filter in a clean glass jar and look at it in a good light. If the fuel is clear and bright
then changing the fuel filter should fix the problem. If the fuel is hazy or has particles floating
in it, it will block filters and it should be replaced before the filter is changed
Posted on Nov 19, 2013
Hard starting in the morning with Quantum 2.7diesel GL
The only things that would affect starting a diesel motor are cylinder compression or injectors. If you are only having problems when starting the vehicle when it has been sitting for a long time, then the issue is not compression. The injectors are most likely leaking down overnight and allowing fuel into the cylinder or they are losing prime back to the pump and it takes a minute for the pressure to build up while trying to start.
Sep 20, 2016 | Toyota Cars & Trucks
I own toyota hilux 2kd d4d that has a morning cold hard start, after first start all is ok
Excellent answer... short & spot on...
(except YOU didn't mention "OIL CONSUMPTION")
toyota hilux 2kd d4d... Not getting a lot of domestic... (USA)
DIESEL information... here (sorry).
From Bill Boyd here in 1994"
Toyota hilux pick up D4D has hard start in the morning but ok after the...
Jul 24, 2016 | Toyota Cars & Trucks
Toyota hilux pick up D4D has a hard start in the morning but ok after the first start, kindly advise
Have a compression test done to determine the engine condition. With the hard start and oil usage it points to a worn rings and a lower compression pressure than is required.
Feb 01, 2014 | 2006 Toyota Hilux 3.0
My diesel pump is not pumping what must i do
Fill your fuel filter all the way up and take precaution not to get any air into pump. Try this several times. Once you get air into some pumps it can be very hard to bleed it off. There should be some way to bleed. Look on pump for bleeder.
Oct 12, 2012 | 2007 Toyota Quantum 2.7
Isuzu 2001 diesel engine won't start
cant start deisel 3.0 lilter sounds like there is no fuel getting to the engine
Jan 19, 2009 | 2001 Isuzu Trooper
F-350 turbo-diesel hard starting
Imagine the white smoke is unburnt diesel. Anybody standing in the middle of it will be able to tell you soon enough.
Most likely culprit is that one or two of the glow plugs aren't getting hot enough. Usually just that the plugs need replacing, but worth checking first that the busbar which runs between them all is getting +12V at the appropriate stage of the process.
A.
Jul 20, 2008 | 1995 Ford F350
Saddleman Rear Row Neoprene Seat Covers Quantum 85-88 19924-40 Logo
109 people viewed this question
Top Saddlemen Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Saddlemen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
