Question about Royal VF1000MX Shredder
Do the blades need lubricating?
Can only shred one sheet at a time
2 Suggested Answers
  • 1218 Answers
SOURCE: Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Posted on Sep 05, 2010
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
My Staples Blade Guard 15 sheet shredder no longer works automatically. Do you offer a solution?
The internal sensor may be blocked with a shred of paper. try cleaning out the paper slot from underneath.
Sep 30, 2014 | Staples Shredder Lubricating Sheets 24pk
Do you ever need to lube a memorex paper shredder
ALL shredders need to be lubricated. When metal turns, it creates friction that, over time, can cause the blades to warp. Just like you have to add oil to a car, shredders must be oiled as well. You can buy bottles of oil at your local office supply store. Just squirt across the top of the blades. Or pour some on a plate, dip a piece of paper in it, then shred. If you want less mess, purchase the pre-lubricated sheets that you can just drop in and shred. Make sure to shred in reverse about half way through to get the best results.
Apr 18, 2014 | Memorex MPS-2800 5 Sheet Cross Cutt Paper...
Lubricate with what product
It's amazing how easy it is to lubricate a shredder, at least the blades portion of the shredder. Go to your local Staples store, or else order on line. They sell lubrication sheets for all shredders. I bought a dozen for less than $10 and they work great. You just insert the sheet and shred it. The unit is lubricated. The Staples part number I got was their part number 602400. Good luck..
Nov 08, 2013 | Aurora Global AS501X-MS Shredder
THE BLADES ARE FULL OF PAPER. SHOULD I TAKE IT APART AND ATTEMPT TO CLEAN IT?
In order to maintain a functional paper shredder, you should clean it out and oil it at least once a month(depending on usage) if not every time you fill it.
I would advise against trying to disassemble the actual blades to clean them out if that's what you mean by "take it apart."
What you can do is unplug the machine, lay the blades up and get a pair of tweezers and remove any large pieces of paper/shredding that might be caught in there.
After doing that you should oil the blades with any lubricant that your owner's manual recommends.
Most shredders suggest a non-aerosol/biodegradable oil such as vegetable oil.
Do not use WD-40 or other canned spray lubricants.
I've found that dripping the oil straight into the blades can be very messy so a good alternative is to lay out a piece or two of scrap paper and soak it in the oil. Then run the paper through the blades as normal.
They also sell varieties of this here: http://www.staples.com/Staples-Shredder-Lubricant-Sheets-12-pk-Shredder-Sheets/product_602400
It doesn't have to be a headache to maintain but proper care can make your shredder last a long time.
Jan 18, 2013 | Royal Sc120 Shredder
Paper always packs up in the blades and it will not cut more than 1 sheet at a time. Sometimes not even that. Any solutions for this? I constantly have to dig the paper out of the blades, even after...
All x-cut shredders should be oiled. Buy some shredder oil ( this is a lightweight oil ) from your local store then pour some of the oil across the cutting blades where you insert the paper. After putting the oil in run the machine in reverse...this will help get the oil all thro the cutting mechanism. Then start shredding 1, then 2, then 3 etc, etc sheets at a time...when you hear the motor starting to "labour" to take the sheets thro'..then you have just about reached the point where "thats its maximum". You should occassionaly shred a sheet of paper with a bead of oil on it ( in an "S" pattern) to help keep the mechanism lubricated. Running the machine at about no more than 75% of its maximum capacity and regular oiling will prolong the machines life.
Dec 15, 2010 | Royal VF1012mx Shredder
Odd metal to metal sound
You can't really clean the blades...however , a x-cut shredder should be lubricated regularly....try putting some shredder oil on a sheet of paper and shredding it...do this a number of times to get the oil down into the cutting blades, see if that helps.
Apr 09, 2010 | Royal VF1000MX Shredder
Overload with one sheet of paper..nothing jam inside .very clean
Should not have a problem with 1 sheet....so...have you ever "oiled" the machine.????? Pour some shredder oild inside to lubricate the cutting blades and try to run the machine in "reverse" for 20 secs or so...then put some oil onto a sheet of paper and try shredding the sheet of paper.
Oct 12, 2009 | Royal VF1000MX Shredder
Jul 21, 2009 | Royal Office Equipment & Supplies
Royal VF1000MX Shredder Logo
85 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
