Question about Dell P1500 Laser Printer
Reset counter select
How do you reset this counter
Looking for keystroke sequence to reset pcu and dev counter on a konica minolta Di3510f. I am able to access tech rep mode but stuck after that
Enter in the service mode,select counter,select special parts counter ,reset to 0 P/c and I/C counter and in Function mode select F8 only you have change the developer,if not changed not use the F8 because damaged the copy quality.
Mar 20, 2013 | Konica Minolta Office Equipment & Supplies
How do I reset 2nd bias transfer roll for xerox 7556
On the 7556 and most other Xerox copiers, follow these steps to reset the counter. You do NOT need to call out a tech.
The supply life counters must be reset when some supplies are replaced.
  1. Log in as the System Administrator or Key Operator.
  2. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
  3. Select the [Tools] tab on the Touch Screen.
  4. Select the [Device Settings] button.
  5. Select [Supplies], and then under Features select [Supply Counter Reset].
  6. Select the required supply item, and then select [Reset Counter].
  7. Select [Reset] when the confirmation screen is displayed.
  8. Select [Close].
  9. Press the [Log In / Out] button on the Control Panel. The Logout screen will be displayed.
  10. Select the [Logout] button on the Touch Screen to exit.
Feb 11, 2013 | Xerox DocuColor 3535 Copier
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
I cannot print from canon ip2770 printer...the orange light flashes five times
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Jul 06, 2011 | Office Equipment & Supplies
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How do I reset the drum counter on MFC-9440CN brother
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
Aug 31, 2009 | Brother MFC-9440CN Laser Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
How do you reset the drum counter for a Brothers MFC-9440CN?
  3. Press OK.
  5. Press OK.
  7. Press OK.
Jan 13, 2009 | Brother MFC-9440CN Laser Printer
How to reset my epson stylus dx5050 printer
If your Epson printer needs resetting you can download the latest software Version of the SSC Service Utility (V4.3) from this link.
Install it and run it, click on configuration, select your printer from both lists ('x' is replaced by a number), close the program with the red cross. The program will run in your task bar, click your right mouse button on the icon for a menu. You can use the appropriate utility for your needs, if your printer needs maintenance due to ink pad being full, select Protection Counter and Reset Protection Counter. If your printer has locked out because you ignored the warnings and continued printing, first select Protection Counter and Clear Counter Overflow, then select Extras and Soft Reset, wait 5 minutes, then select Protection Counter and Reset Protection Counter.
Sep 23, 2008 | Office Equipment & Supplies
Reset Compaq IJ650 ink counter
go to the printer properties and select maintenance then select reset ink counter
Jul 22, 2008 | Compaq Inkjet IJ650 Printer
Dell P1500 Laser Printer Logo
19 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
