Question about Motorcraft 2011 11 Ford Crown Victoria Brake Disc-2011 Ford Brake Disc
No high seed on wipers
Wipers stay on low seed
  • 4 Answers
Need a new high low switch or check relay!
Posted on Nov 19, 2013
Wiper control module location on a 2000 f250
Did you check the wiper relay's in the under hood fuse box ? There are two ,wiper run/park relay & wiper high low relay ! Also ,did you check fuse's ? fuse # 11 - 30amp location cental juction box . The wiper switch is a input to the GEM module . Generic electronic module . The module in most cases isn't the problem ! Learning how to test these electronic systems is , people do not know how to test so they just replace parts . What they should do is take the vehicle to ford certified Technician who has the knowledge and testing equipment to find an fix it .
The generic electronic module (GEM) receives inputs from the following:
  • multifunction switch
  • anti-lock brake control module (vehicle speed signal [VSS])
  • ignition switch
The GEM uses these inputs to control the outputs to the following:
  • windshield wiper high/low relay
  • windshield wiper run/park relay
  • windshield washer relay
  • rear wiper motor relay
  • rear window washer relay
  • GEM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1240 Wiper Washer Rear Pump Relay Circuit Failure GEM GO to Pinpoint Test K . B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery + GEM GO to Pinpoint Test K . B1342 ECU is Defective GEM CLEAR the DTCs. REPEAT the GEM self-test. If DTC B1342 is retrieved, INSTALL a new GEM. REFER to Section 419-10 . B1431 Wiper Brake/Run Relay Circuit Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the windshield wipers stay on continuously, GO to Pinpoint Test C . B1432 Wiper Brake/Run Relay Circuit Short to Battery GEM GO to Pinpoint Test B . B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure GEM GO to Pinpoint Test D . B1436 Wiper Hi/Low Speed Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test D . B1438 Wiper Mode Select Switch Circuit Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If both the windshield and rear window wipers are inoperative, GO to Pinpoint Test L . B1441 Wiper Mode Select Switch Circuit Short to Ground GEM GO to Pinpoint Test C . B1446 Wiper Park Sense Circuit Failure GEM If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
    If the speed dependent interval mode does not operate correctly, GO to Pinpoint Test G .
    If both windshield and rear wipers are inoperative, GO to Pinpoint Test L . B1450 Wiper Wash/Delay Switch Circuit Failure GEM If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
    If the wash and wipe function does not operate correctly, GO to Pinpoint Test F .
    If both the windshield and rear wipers are inoperative, GO to Pinpoint Test L . B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM If the windshield wipers stay on continuously, GO to Pinpoint Test C .
    If the wash and wipe function does not operate correctly, GO to Pinpoint Test F . B1458 Wiper Washer Pump Motor Relay Circuit Failure GEM GO to Pinpoint Test F . B1460 Wiper Washer Pump Motor Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test F . B1473 Wiper Low Speed Circuit Motor Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the windshield wipers do not operate at high or low speed correctly, GO to Pinpoint Test D .
    If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E . B1475 Accessory Delay Relay Contact Short to Battery GEM REFER to Section 501-11 . B1476 Wiper High Speed Circuit Motor Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the intermittent windshield wiper does not operate correctly, GO to Pinpoint Test E . B1611 Rear Wiper Mode Switch Circuit Failure GEM GO to Pinpoint Test H . B1614 Rear Wiper Mode Switch Circuit Short to Ground GEM GO to Pinpoint Test I . B1820 Rear Wiper Motor Up Relay Circuit Short to Battery + GEM GO to Pinpoint Test H . B1839 Rear Wiper Motor Circuit Failure GEM GO to Pinpoint Test H . - All other DTCs. GEM REFER to Section 419-10
Jun 06, 2017 | Ford F-250 Cars & Trucks
WHERE IS THE WIPER/WASHER FUSE LOCATED ON 2007 PONTIAC TORRENT
In the under hood fuse box , should have diagram inside the lid . Front wiper's or rear ? Front fuse # 36 - 25 amp. Plus Two relay's PCB hi and Wiper PCB relay . Wouldn't think this being fuse problem . Wiper switch , motor etc... The wiper's are control by a computer . BCM - body control module .
The windshield wiper/washer system consists of front and rear wipers. The front and rear wipers are operative when the vehicle is in accessory or run. The front wipers have 4 different modes: Mist, Intermittent, Low, and High. When the front wipers are in the intermittent mode, there are 5 delay modes to chose from, commanded by the windshield wiper washer switch through the body control module (BCM). The rear wipers has an only one mode.
If the fuse is bad , could have a short to ground or wiper motor pulling to much current (amps) . Fuse's don't just blow for no reason ! Could also have DTC'S - diagnostic trouble codes stored in the BCM .
DTC B3715
DTC B3873
DTC B3875
DTC B3922
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two different PCB relays which control the desired wiper speed, high or low.
DTC B3922 00: Front Wiper Function Select Circuit
The PCB relay's are non- servicable , replace fuse box . Soldered in Your best bet mit be to take it to a qualified repair shop .
Feb 20, 2017 | Pontiac Cars & Trucks
'07 Impala Wipers Work Intermittently
Did you check for voltage at the wiper fuse? My info says that fuse is hot all the time. Use a digital multimeter. Everything off, take a reading across battery posts, the generic spec for a full charge is around 12.6 volts. You should get close to same reading at the wiper fuse, hopefully. When checking voltage at the fuse, use chassis ground not the other leg of fuse. There are wiper relays, those are pcb relays, they are soldered into the fuse box, you can't pull them out. Your bcm is also involved with those relays. Your multifunction switch basically tells the bcm you turned on your wipers, then the bcm controls voltage or ground for the relays. You can see wire color for hi and lo speed voltage. Maybe a problem with fuse box or wiring circuit if voltage is low? I hope this was of some help?
Dec 04, 2017 | 2007 Chevrolet Chevrolet Impala LT
Wipers only work on high on 2001 navigator
i would say the wiper motor is the culprit.
Sep 27, 2012 | 2001 Lincoln Navigator
Wipers would not park, customer forced down wiper arm and broke off arm. Now no electric to wipers.
Before 1995 Ford interval wiper systems mainly consisted of a switch, the motor and the interval governor (also called the wiper control module or 'WCM'). The basic wiper systems just parked the wipers at the end of their travel at the base of the windshield and involved just one park switch.
The more complex systems not only stopped the wipers at the base of the windshield, but would actually recess them below the windshield to park them. This involved using two park switches to turn the wiper motor in a reverse direction. These were installed on the Crown Victoria, Grand Marquis, Town Car, Taurus and Sable.
The wiper switch (named 'Multi-Function Switch' on most models) had a common return or ground circuit and two input or signal circuits to the WCM. Basically, the switch was two modified potentiometers that varied the resistance to ground for the two signal circuits. When the wiper switch was placed in the low or high position, the WCM looked at only one of the circuits- the 'mode input' -and controlled the wiper motor accordingly. If the wiper switch was placed in any of the interval positions, the mode input told the WCM that the switch was in an interval position. The WCM then looked at the second input - the 'delay input' - and used it to determine the amount of delay between wipes.
1) To run the wipers on low or high speed, the WCM provided constant power to the wiper motor on the proper circuit to provide the requested speed. Dual park switch motors
1.1 The first park switch operated basically in the same way as the single switch systems.
1.2 The second park switch worked in the opposite manner- when the wipers were off the park position, the second switch provided a ground for the wiper motor. Power and ground were now provided by the park switches.
1.3 When the wipers needed to park, the polarity of the switches changed, and thus provided reversed voltage to drive the motor in the opposite direction.
2) To run the interval wipers, the WCM applied voltage to the wiper motor only momentarily to get the wipers off the parked position.
3) The electro-mechanical park switch made a circuit between the power feed in and the output to the WCM. Power was provided from the park switch through the WCM and back to the wiper motor.
4) When the wipers reached the park position, the park switch made a circuit between the ground and the output to the WCM, and the motor stopped running. The wiper motor and the wiper switch have remained much the same as the single park switch motors of the past.
The main difference is that the switch has become an input to the GEM instead of the WCM.
1) When the wiper switch is placed in the low or high position, the Run-Park relay is grounded by the GEM to provide constant voltage to the High-Low relay, which then provides voltage to the proper circuit of the wiper motor.
2) High-Low relay is in the low speed position unless grounded by the GEM.
3) The park switch not only feeds the Run-Park relay but is now also an input to the GEM. This tells the GEM when the wipers are in the parked position so it can de-energize the Run-Park relay.
4) When any of the interval positions are selected, the Run-Park relay is momentarily grounded to get the wipers off the parked position
5) The park switch then provides voltage to the other set of contacts in the Run-Park relay.
6) When the GEM de-energizes the Run- Park relay, voltage is still provided from the park switch to the High-Low relay and the wipers complete the stroke.
Click over diagrams for zoom:
Hope this helps.
Feb 08, 2011 | 1993 Mercury Grand Marquis
I have a 87 relient that is experiencing wiper problems. low and high speed work ok, delay does not function is stays in low. when switched from delay to either low or high wiper quit functioning. a click...
To the best of my knowledge, no parts are available for this problem.
This will be a big hunt for you to try to get the help you need.
Try car parts stores, car dealer ships, then go to Amazon and finally e-bay.
Feel free to take any side trips you wish in the looking.
I have had similar problems myself with malfunctioning delay circuits.
Perhaps your best bet its to try to find an older mechanic who knows how to by-pass the problem and cut the delay out of the circuit.
God bless your search.
Sep 08, 2017 | 1987 Plymouth Reliant
Windsheild wippers stay on
There are 4 positions to the wiper switch (OFF, AUTO, LOW, HIGH). If the wipers stay on even in the OFF position, then the self-park is not working and you probably have to replace the motor.
Dec 07, 2009 | 2002 Oldsmobile Aurora
Wipers dont work on high.
you need to replace the window wiper motor.. it doesnt go high enough and stay at that speed for a long time.. its obviously defected
Jun 02, 2009 | 1994 Oldsmobile Cutlass Supreme
Delay wipers don't work.
Try making sure the connection is good.
If it is then you should try replacing the wiper switch.
Brandon Bird
Jan 25, 2009 | 1999 Jeep Cherokee
Motorcraft 2011 11 Ford Crown Victoria Brake Disc-2011 Ford Brake Disc Logo
46 people viewed this question
Top Motorcraft Computers & Internet Experts
David Payne
David Payne
joel920368
Phillip Hicks
Phillip Hicks
Are you a Motorcraft Computer and Internet Expert? Answer questions, earn points and help others
