Garden Logo
Posted on May 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing starter pull cord on Cub Cadet mower
Anonymous
Level 2:
  • Expert 34 Answers
  • Posted on May 06, 2009
Anonymous
Expert
Level 2:
Answers
34
Questions
0
Helped
27523
Points
117
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
4 Related Answers
Anonymous
  • 222 Answers
  • Posted on May 27, 2011
SOURCE: having problems replacing pull cord
There are a million videos on Youtube, but you gotta love this guy. He does things one-handed. Every recoil is basically the same so watch this video and you'll get the idea. One note here: notice that the guy keeps his thumb TIGHTLY on the recoil while he puts the handle on (with one hand!). He never mentions this, but you may want to put a clamp or Vise-Grip (gently) to hold it or your rope will go bye bye up inside and you'll have to start over. Once you've done one, you'll be an old pro at it. Good luck.
Oh, here's the video link: http://www.youtube.com/watch?v=i3ZMVFi0yqY
James
Anonymous
  • Posted on Apr 20, 2011
SOURCE: i have a cub cadet
i have a cub cadet 173 cc, mower,not starter,check the gas,oil,filter,blades all is good,but the electric stared not star,i need help.
Anonymous
  • 4 Answers
  • Posted on Jun 07, 2009
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Anonymous
  • 205 Answers
  • Posted on Apr 15, 2009
SOURCE: LOW VOLTAGE @ STARTER ON CUB CADET MOWER
Check for good connection on the Ground wire
5answers
Cub cadet LTX 1045 Has no electrical power
Hi Charles.
this is all i can find on the net.
Start at the red (+) battery post and follow the battery cable to the starter solenoid. On the same top post of the solenoid where the battery is hooked there is another smaller red wire. Follow this small red wire and it will lead you directly to the fuse.
A Cub Cadet lawn mower won't turn over when it isn't getting power to the starter motor to spin the engine. This can be due to a bad battery; loose or corroded wiring; corroded terminals; bad ignition key switch; faulty safety switch; blown fuse; bad starter solenoid; or faulty starter motor.
7 Reasons Your Cub Cadet Lawn Mower Won't Turn Over or Crank You have finally found time in your busy schedule to mow your lawn. You're happy to be able to get it done and out of the way. However, this time your mower won't turn over. I have put together a list of items to check when you run into this problem.
Make sure you are following all safety precautions as shown in your owner's manual. If you are uncomfortable working on your Cub Cadet's starting system, contact your local Cub Cadet dealer or a knowledgable mechanic.
Dead or Bad Battery in Your Cub Cadet
A dead battery won't provide the power you need to turn over your Cub Cadet. Keep your battery charged, especially during storage, to extend your battery's life. Test your battery using the steps in the article "5 Things That Are Draining the Life of Your Lawn Mower Battery".
Charging a Battery: Use a battery charger to charge your 12-volt battery. Before you continue, wear protective gear to protect your eyes and skin from electrical shock. Follow these steps to charge your lawn mower battery with a charger:
  • Access the battery and terminals. You may need to use a screwdriver to uncover the battery. Do not remove the battery from the casing.
  • Connect the charging cables beginning with the positive cable first. This is the red cable or the one with the plus sign. Place the cable on the positive battery terminal.
  • Attach the negative cable to the negative battery terminal. This is the black cable or the one with the negative sign.
  • Do not touch anything that doesn't have a rubber coating to prevent electrocution.
  • Set the charger's voltage and amperage level to the desired level. The average volt level for lawn mower batteries is usually 12 volts. More amperage charges the battery faster. Start with two camps and work up to no more than 10 amps. A slow charge is best.
If the battery fails to hold a charge it must be replaced with a new battery. You can purchase a new battery at your location lawn mower dealership, hardware store or automotive store. Bring your old battery with you. Most places will charge you a core fee unless you provide them with your old battery.
Loose or Wires and Connections in Your Cub Cadet
Wires and connections can become loose with the constant vibration of your Cub Cadet. Make sure they are secure. While checking the connections and verifying the continuity is good, make sure the terminals are free of corrosion.
The outdoor elements can cause moisture around the connections causing corrosions. Try to remove this corrosion using a wire brush and a baking sold solution (2 cups water to 3 heaping tablespoons of baking soda). Replace the terminals if the corrosion is too severe.
Bad Fuse on Your Cub Cadet Lawn Mower
A fuse is installed to protect your Cub Cadet's electrical system. Check your mower to make sure you don't have a blown fuse. If you're unsure if the fuse is blown, you can check it by placing a multimeter probe on each prong of the fuse to measure resistance.
A resistance reading near 0 means your fuse is good. An infinity resistance reading indicates a bad fuse.
Replace a blown fuse with a fuse with the same amperage of the fuse you are replacing. If you continue to blow fuses, you should bring your Cub Cadet to your lawn mower dealership or lawn mower repair shop to troubleshoot the root cause.
Bad Ignition Switch on Your Cub Cadet Lawn Mower
The ignition key switch can be the culprit if you insert the key and turn it to find nothing happens. Your Cub Cadet will fail to turn over and start.
Check the switch using a multimeter to check continuity to determine if the ignition switch is the problem. To do this, look for the prongs mark B for Battery and S for Starter Solenoid.
Insert the key and turn it to the start position. With the multimeter set to measure resistance, touch one probe to the B prong and the other probe to the S prong.
A good ignition key switch will measure resistance near 0 ohms. A bad ignition key switch will measure infinite resistance and will need to be replaced.
Bad Safety Switch on Your Cub Cadet Lawn Mower
Your Cub Cadet has an operator presence control system installed to keep you safe. A safety switch can be defective and cause your Cub Cadet to fail to turn over.
Test your switch using a multimeter. You can also temporarily bypass the safety switch to identify a bad switch, but only do this for troubleshooting purposes.
Never operate a mower without the safety switch. Never run a mower when a safety switch is bypassed. A safety switch can save you from serious injury and you never know when you're going to need it.
Bad Starter Solenoid in Your Cub Cadet Lawn Mower
A starter solenoid is an electromagnetic switch that, when engaged, initiates the starter motor to turn over your Cub Cadet's engine.
The starter solenoid can go bad when the spring becomes weak or the copper plate begins to corrode. A weak starter, bad battery or bad ground can also cause the solenoid to fail.
Before you test your starter solenoid, you must have a fully charged battery. Continue testing the solenoid by using the steps to diagnose a bad starter solenoid in "How to Tell Your Lawn Mower Solenoid is Bad".
Bad Starter Motor on Your Cub Cadet Lawn Mower
Once you have ruled out the battery, cables, wiring, ground and starter solenoid as being the reason for your Cub Cadet won't turn over, it's time to look at the starter. The starter can be removed and tested.
I recommend having your local repair shop that specializes in starter and alternator repairs test your starter and rebuild it if possible before just throwing a pricey new starter at your Cub Cadet mower.
Still Having Problems with Your Cub Cadet Mower? If the above list did not resolve your problems, I put together a guide of common mower problems and solutions. You will find links to more in depth articles for each of these common issues. You can find the article at "Common Cub Cadet Lawn Mower Problems".
If none of this helps you out i dont know what you are going to do.
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Broken Cub Cadet
I dont own one or there but it is an easy repair. Find a wrench/socket that will fit the 3 or 4 bolts holding down the pull cord (recoil) cover and remove them and the cover. (Prob. a 10 mm socket) Then wrap a cord/narrow rope CLOCKWISE around the pulley 3-5 times and prepare mower to start as you normally would and pull the rope. Now you can cut your grass before it becomes unmanageable. Take the recoil to any small engine repair shop and have them replace the rope and then you can reinstall the recoil. In my area the charge $7-$10 for this.
May 20, 2013 • Garden
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
2answers
Broken pullcord
before you rethread it you must spin housing counter clockwise till you feel tension (if you let it go you have to restart ) then tread it
3helpful
Jun 07, 2009 • Garden
1helpful
My cub cadet src 621 has been difficult to start since the headgasket was replaced. In fact pulling the starter cord is not only difficult it sometimes kicks and almost rips your arm off. Why is is so...
If its ripping you arm off the timing is off. Check the flywheel key it is more than likely sheared off. Pull the cover and look down on the flywheel and you should see this.Your unit is not clear to me so whatever unit you have check the timing and when its right it will not pull your arm off.Good luck.
Top Garden Experts
Jay Finke
Jay Finke
john h
