Question about Snapper NXT2346 46" 23HP NXT Lawn Tractor
Snapper nxt no power
There is no power at all even with a fully charged battery. It is a push button start and should at least show me the heads up display when the button is pushed... but not even that comes on. What could the problem be?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
No voltage. blown fuse, poor connection at the battery cables. you need a wiring diagram to test further. If you can't read the wiring diagram. seek professional help
Posted on Nov 27, 2013
Snapper nxt riding mower, console stays active and drains the battery, what can I do?
Until you locate the problem just disconnect the negative battery terminal till ready to use again.
Apr 09, 2017 | Snapper Garden
My Snapper NXT2346 just stopped while mowing checked battery is ok, no power to starter or safety switch, changed fuse, seat switch check seemed to be ok - any suggestions?
Those tractors have a few safety switches and they all have to be engaged in a closed position for you to have ignition and have unit operate. Did you check the obvious ? - ignition switch?
If it just stopped dead while you were mowing then the ignition had to have been interrupted. That switch powers both the starter and ignition circuits.
Sep 11, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
SR1642 Snapper rear engine, what is the fuse for?
Most the fuse is for starting. The park brake probably has a safety switch. It needed adjusted.
Jun 24, 2014 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Power button not working!!! This is different though....
This is a common problem that I run into. The battery will show charged when it really isn't. Take out the battery, plug the charger into the computer and try turning it on. If this works, you have a bad battery and it will need to be conditioned or replaced. If this doesn't work it could be a serious hardware issue.
Jun 25, 2013 | Dell Studio 1558 Notebook
Nxt 2346 trouble shooting guide
check for a lock pin that you have to move out of the way. push on the deck height control pedal and pull the lock lever out of the way. this is what keeps the deck up when travelling.
Jun 15, 2013 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Suzuki vinson 500
could be a bad ground or a bad connection on the positive wire to starter. try turning the ignition on and jumping from battery to postive on starter. good luck!
Jun 04, 2013 | Motorcycles
Engine will not start
Try taping on the starter while you are turning they key. The starter may be bad or drawing to much power. If the engine doesn't roll over use a voltmeter to check and see the ansers to these questions. Is power at the starter, is the solenoid good is it providing power to the starter, is the key ignition providing power to the solenoid
Oct 17, 2012 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
My nxt won't start up with a good charged battery. actually I have 2 nxt bricks with this problem. 1. Battery... Battery works on another nxt battery shows full charge. I've also connected the power...
The clicking sound is supposed to tell you that the NXT is on while resetting the firmware. You probably disconnected it while it was updating it. Try updating it again.
Jul 19, 2010 | Lego Media Lego Mindstorms
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Snapper NXT2346 46" 23HP NXT Lawn Tractor Logo
432 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
