Question about Honeywell EnergySmart Electric Radiator Heater HZ-789
Will not turn on
Heater was working but stopped working and would not turn back on when depressing on button
Have a Goodman GDH8 that the heat is not coming on, what do I need to do to get it running?
depress button for 2-3 sec light pilot manually then turn valve to on if it doesnt stay light u need to clean thermocoupler or replace it
Oct 05, 2016 | Goodman Heating & Cooling
2006 water heater. Is it only run on gas. How do i turn it on.
If it is a regular gas hot water heater You need to turn the knob on the gas valve to pilot. Depress and hold the knob down. while doing that press the green button on the side of the valve . you may have to repeat that a few times. that button makes a spark to light the pilot. You need to hold the knob down for about a minute more to let the thermocouple heat up and signal the gas valve that it has a flame. release the knob . if the pilot flame stays on ,turn the knob back to the on position. If that does not work repeat if still not working give more info. Make and model of heater
Feb 03, 2015 | Water Water Heaters
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Sunbeam tower heater just stop working. How do I repair it?
Make sure the trip button on the bottom of the heater is fully depressed when sitting on the floor. This is a safety tip over device. The button on the bootom must be in contact with the floor surface or it will shut off.
Feb 09, 2012 | Heating & Cooling
This Morning I turned on my heater (to auto) after changing my air filters and it went on and when it clicked off and i tried to turn it back on it stopped working, the thermostat works and i changed the...
Make sure the panels are put back on securly, the door safety switch may not be depressed. Also check the circuit board in the heating system for a blown fuse.
Nov 23, 2010 | Honeywell Programmable Thermostat Heater
How do you turn off the child lock on a RinnaiRCE229H natural gas Heater?
Basically hold in the child lock button for two seconds. If the child lock was activated and you then turned the unit offt the child lock remains set and will stop you turning the unit on. To deactivate, make sure you have the power lead pluggeed in and turned on. Before you depress the ON/OFFbutton, hold in the child lock button for two seconds. This will deactivate the child lock and allow you to turn the heater on.
Here is a link to a users manual, check out page 11.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/150.pdf
Aug 15, 2010 | Heating & Cooling
Followed start-up procedures, purge blower started up for 10 seconds then stopped. Observed circuit board light blinking constantly.
there is a button under the cover if it is not depressed the unit will shut down make sure the cover is depressing switch
Oct 10, 2009 | Goodman GMS90703BXA Heater
Kirkland outdoor heater will not stay lit
The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
May 31, 2009 | Stainless Patio Heaters - Steel Deluxe...
Can not start propane heater.
the thermo couple is bad.install new on and all will be well.give me the model number and i'll try to get you a part number
Mar 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Honeywell EnergySmart Electric Radiator Heater HZ-789 Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
