Question about Mitsubishi WD-52525 52" Rear Projection HDTV
There are blue dots showing up all over the tv, what is the problem and solution
What do I need to do to get rid of the blue dots showing on the screen
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Feb 18, 2012 | Sony Televison & Video
I have a blue icon with dots on it at the top of my the phone in the middle of the screen. How do i get rid of it?
It sounds like the Blackberry Messenger Icon which means you have messages in Blackberry Messenger. To get rid of the icon you simply have to go read the messages. This is the only icon i can think of that is blue with white dots that would be on top of the screen.
May 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have blue hazy streaks and tiny blue dots on my lcd tv
You need a light engine. I do not remember if your model is still under Sony's recall. You might want to call them.
Jul 08, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue dotted line of right side of paper
Sounds like the cyan photoconductor unit needs to be replaced. Usually what ever the color dot is that photoconductor has a pinhole in it and the only to get rid of it is to replace it.
Apr 06, 2010 | Ricoh Aficio SP C411DN Laser Printer
Blue dots on my tv
Bad Light Engine Call Encompass Parts Dist
1-800-638-3328 They have 7 of them in stock
Part number# A-1606-008A optic block/light engine
Feb 15, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Two blue dots on the screen
its sounds like the guns has burnt your yube, when switching of does your tv show a bright circle in the middel, or while watching. Smack your tv on the side while on see if the picture goes away or make a bright circle in the middel, this is caused by a bad solder joint but you wont get rid of the bunt pixels sorry.
Nov 26, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue screen on tv
I too have the same problem with the blue screen and also some dots in the center of the screen. I went to the sony site (www.sony.com) and found the answer. They will repair the unit until Dec 31, 2008. hope this helps
Nov 09, 2008 | Televison & Video
Green and Blue spots on screen
Sounds like stuck pixels, you really can't fix that. Do some google research if you are curious what a stuck pixel is.
Oct 30, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
