Question about Kenmore Refrigerators
Slight smoky smell and freezer food/ice taste smoky
A month ago we kept hearing water running in our freezer. Thought it may be the defrost cycling on too much. Ice in ice maker kept melting some then refreezing. Husband took freezer apart and couldn't see any problems. Thought maybe door just wasn't getting shut properly. Seems to be working much better after re-leveling. Today freezer and my extension the refrigerator has a smoky smell to it and the ice and some food has tasted smoky. I read if the seals are going bad they can give off that smell. Is this true? Any other issues cause that? We have very little money and need to solve this asap. Thanks.
Sounds like your motor is is burning out or someing inside the fridge is burn
Posted on Nov 19, 2013
  • Sandra
    Sandra Nov 21, 2013
    More info: took everything apart and can't find any problems. Still has an off smell. Everything is clean. Everything is staying cold and frozen. Haven't checked the drip pan yet because its bolted in hard place. Smell it the most when fan is running.
  • 399 Answers
SOURCE: Bad water & ice cube taste
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Posted on Sep 16, 2008
  • 400 Answers
SOURCE: ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Posted on Mar 09, 2009
philbran
  • 242 Answers
SOURCE: Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Posted on Apr 14, 2009
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
aasc
  • 1606 Answers
SOURCE: DSS25KSRD SS GE Adora refrigerator- ice in tray
It sounds like the # 4 thermistor is bad . You will have to remove the lower inside rear freezer panel ( 2 or 4 screws ) and on the top of the coils , you will see a 1 " long torpedo looking piece , clipped on , with 2 white wires going to it . Part number WR55X10025 . This thermistor , tells the maon control board , the temperature of the freezer coils ( evaporator ) and when to defrost and when to stop defrosting and turn the compressor back on . There is also a defrost thermostat which cuts the heater off to keep from over heating , but I do not believe this is part of your problem . You should also replace the # 5 thermistor , located behind the oval grill , mounted on the lower right side of the freezer . This thermistor , tells the main control board , the temperature of the freezer section .
Posted on Oct 21, 2009
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
Youtube
taste the water coming out of the filter ? should come from a cold water line, not the hot water line, funky smells and tastes come from your hot water heater. and I don't want to hear the hot water freezes faster bs. hot water heaters are full of stuff you don't want in your body. So if the water tastes ok....
sounds like you need to give the entire fridge a defrosting, clean it up real good. also have baking soda ready for monthly treatments, just crack a box open and stick it int the fridge or freezer.
These ice machines never did make quality ice as they just freeze still water, witch make cloudy, less than savory ice.
If you are a big ICE lover like me. a under the cabinet flowing ice machine is the best ice, as it last the longest(almost clear) and has no ill flavor.
Jay the pool pump guy longwood
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
Refrigerator and freezer musty, freezer burned smell? ?
they should be washed every2 months use baking soda and a box of fridge charcoal
thumbs up
Aug 17, 2009 | Frigidaire GLRS264ZA Side by Side...
I have a bad smell and taste in water and ice from fridge/freezer
Take out all shelves and accessories that can be removed. Wash these thoroughly with a mild detergent (dish washing liquid and warm water) and rinse thoroughly. Allow them to air dry completely.
* Wipe the inside walls of the refrigerator and freezer down completely with a solution of 1 quart warm water and 2 tablespoons of baking soda. Wipe the walls completely dry.
* Leave the doors standing wide open. Use a fan to circulate air through the cabinets for several hours to completely dry the inside walls. After several hours, turn the fan off.
* Replace the shelves in the refrigerator. Place shallow trays of one of the following deodorizers on the shelves of the refrigerator and freezer:
o Baking soda
o Activated carbon (used in aquarium filters, can be obtained at a pet store)
o Cat litter
o Fresh and unused coffee grounds (this may leave a coffee smell that would dissipate after several days)
* After 24 hours, plug in the refrigerator and allow it to cool for several hours with the deodorizer still in place. Once cooled to normal operating temperature, remove the trays of deodorizer and put your food back into the refrigerator and freezer.
* Keep some cereal size bowls of a deodorizer in the freezer and refrigerator cabinets for several days
Feb 28, 2009 | Kenmore Refrigerators
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool Side By Side Refrigerator
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
* You can call our toll-free number to order parts (credit card orders only.)
Please call 800-599-7569 M-F 9:30am - 5:30pm.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Sep 05, 2008 | Whirlpool ED5FHEXMQ Side by Side...
GE side by side water dispencer area Leaking
* You can also schedule service by calling our toll free number:
800-374-4432 M-F 9:00am - 5:30pm.
Back
Back
3. Noises / Sounds.
* Dripping sound.
* Running water.
Back
4. Taste and odors.
Back
Back
Sep 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
