Question about RaidMax AURA ATX-927WB Black SECC Steel ATX Mid Tower Computer Case ATX Mid-Tower Case
Power button switch
The power button switch on the front door wont turn on it need to be replace wonder where i would be able to find one so i dont have too buy a new tower
    Novelist:
    Scholar:
  • 194 Answers
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Posted on Nov 20, 2013
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
I have a 2000 Cherokee sport 4 door, 4wd. The left windows work fine but the right front and rear do not work. The LED light on the switch itself is lit. I replaced the window regulator for the front left...
Take a door panel off on the right, and see if you have power and ground going to the regulator when you press the button. If you dont, then your going to be chasing wires
Mar 25, 2010 | 2000 Jeep Cherokee 2WD
Directional Buttons dont work
Friend you need to clean your back button with brush there is something stuck on it. or your switch button may break just replace it with new one
Jun 05, 2009 | Sony Walkman NW-A808 MP3 Player
94 Grand Am Power Lock - front drivers side door (Trying again)
First, I'd recommend buying (or borrowing from the library) a Chilton or Haynes Manual to help finding the parts and how to access them. They'll save you a lot of time and headaches.
Then I'd try replacing the door lock motor. The motor itself should be just behind the inside door panel. Many times these motors, after years of wear and tear, break the teeth off the internal gears, causing a loud grinding/whirring noise but not allowing the doors to fully lock or even lock at all.
You can either buy a new motor from an auto parts store, but I've found that by checking with the local junk yard turns up some really good deals. Try to find a car that is the same make and model but maybe a newer year, bring the old motor with you, and make sure they look exactly the same down to the mounting holes.
I hope I could help you fix this issue. Good luck and don't forget to rate! Thank you!
Dec 08, 2008 | 1994 Pontiac Grand Am
My camera wont turn on
Hi
Could be a couple different things. Was the camera dropped or exposed to liquid? If so it may be a problem that needs repair by replacing the damaged parts.
One thing for you to try is to find the small battery door switch beside the memory card slot, is it damaged or missing? Without this switch the camera will not turn on. Put in the battery and with the door open press down the switch gently with a pencil. Now press the power button... does it power?
If it's not that switch then it's most likely the fuse which has shorted out. If you can solder well then you can replace the fuse, they are pretty cheap to buy. Another option is to buy a defective camera online and make one good camera from the two.
If that's not an option you can have somebody repair it for you. If its out of warranty Canon will want $150+ to do it.
DONT throw it in the trash! It's still worth money even if you don't want to repair it, sell it online or sell it to us; we are a digital camera repair business (Google: Darntoothysam com) and would buy it for parts if we can't get the parts to fix it for you.
Hope this helps
Good luck from Darntoothysam com: Affordable digital camera repair
Thomas
Oct 19, 2008 | HP Photosmart M22 Digital Camera
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
RaidMax AURA ATX-927WB Black SECC Steel ATX Mid Tower Computer Case ATX Mid-Tower Case Logo
152 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
gaucherre
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
