Question about ECHO, Inc. PB-251C Handheld Blower
Need diagram for fuel line hookup on echol pb1000 blower
Which lines go wheere to the carb?
4 Suggested Answers
roadtech7
  • 297 Answers
SOURCE: Fuel is not going up the fuel line to the carb. I
What model blower is it? It should have two or three fuel lines going to the tank. One pulling fuel from the tank, with the filter on the end of it. The second one is a return line from the primer, and the third ,If their is one is the vent line.
Make sure when replacing the fuel lines that you do it one at a time so as not to confuse the pick up and discharge hoses.
The primer, when it has the hoses connected correctly, will have SLIGHT pressure when being depressed. If the hoses are crossed, the primer will be very difficult to push down and will NOT spring back up, it will stay "stuck" down for a few seconds.
Hope this helps.
Posted on Nov 04, 2010
2strokeJim
  • 577 Answers
SOURCE: echo pb251h. Blower will only
when the carb was "rebuilt" Did you pull out the screen and clean it out and also did you pull needle and diaphragm out and clean it out good, because if the needle is not working or the neoprene tip is swollen your needle adjustment will be out of whack,sometimes carb cleaner will make it swell up to where it won't open enough to get fuel through it....suggest you replace the needle and adjust your height of the tab to flush with the body of carb and make sure you have a good diaphragm in it along with new check-valve diaphragm, then make sure your primer is hooked up right ..it should be pulling fuel through the filter to carb and through carb and back to tank,your problem is definitely in the fuel system, keep trying different things you will figure it out
Posted on Jun 15, 2011
2strokeJim
  • 577 Answers
SOURCE: stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate
2StrokeJim
Posted on Nov 19, 2011
Poulanproleafblower not primeing
Either your fuel is broken inside the tank or your carb is blocked up inside. Empty the fuel tank and look inside and see if you fuel inlet line has a little plastic or metal filter on the end. *(this is called a "clunk") The clunk keeps the fuel line in gas no matter which way you have the blower tilted. Chances are you will see the clunk just laying in the bottom of the tank with whats left of the fuel line still attached. If the fuel line and clunk are intact then your need to get a diagram of the carb and do a dissembly and cleaning. The carbs have tiny screen filters which jam up with debris and gelled fuel. So a rebuild kit with new filter would be a good thing to get if your carb is cruddy. You can look online at Poulanpro and see which kit you need to buy. They are 10-15 bucks usually. New fuel lines is also a good idea if you are going this deep into the unit. Be safe and good luck!
Aug 25, 2014 | Poulan Pro Gas BlowerVacuum ()
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Hi I have a PB1000 echo leaf blower, I have spark and compression,although there is no primer bulb on this model, so the fuel must have to be vacumed with fuel pump. I used the choke and it still...
Try a tiny spray of Starter Fluid in your machine. If it runs for a second then dies,,,, it would indicate that you have a Fuel problem. Broken gas line of gummed carburetor. Ethanol gas is known for ruining both gas lines and carburetors.
Aug 29, 2013 | Garden
Need to know how gas lines go on a RGB3100 they rotted off need to see a diagram
I don't have a diagram, but I can explain to you the fuel line routing.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Jun 12, 2011 | Ryobi Garden
I have a Ryobi 700r trimmer - I needs a diagram of all the fuel line hookups
<div id="ms__id6" class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.<br />If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.</span> </div><!-- from fixya rte -->
Aug 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need a diagram for the fuel lines on a ryobi 31cc trimmer plus 15" from the fuel tank thru the primmer bulb to the carb for both lines
Don't quite understand your dilemma... there are only two fuel lines which go from the tank to the carburetor.....if looking at the engine from the back, the fuel line on the left is the intake line and the one on the right is the fuel return line....on the back of the carb are two fuel line brass inserts...they are inlet on left and return on the right....hope this helps ;-D
Jul 15, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My echo pb1000 gas blower wants to stall at high speeds, run fine otherwise, could it need a carb kit or maybe a fuel filter?
Yes it could need both of them plus some fresh gas mixture to boot. I would start with the fuel filter and then go to the carburetor.
HTH
Good Day.
Oct 26, 2009 | Toro 51599 Electric Blower 12 Amp
Echo PB1000 leaf blower will not start
Check fuel lines and fuel filter. If unit has been sitting all winter carburetor may need to be overhauled.
Mar 29, 2009 | Garden
ECHO, Inc. PB-251C Handheld Blower Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
